David C
In Memorium
Jacob,
I was being kind and assuming that you might have something like a hard Arkansas stone.
David
David
Cheshirechappie":1318llf2 said:Karl's point about how sharp an edge needs to be for different tasks seems to me the key point.
I have a black "surgical" Arkansas stone. It's too fine for woodwork purposes. Probably why it's termed "surgical".David C":3c7yukdi said:Jacob,
David
It's sapele which set me off on the perfect planing hunt. It's not hard all over, quite the opposite in parts, and very crossed reversing grain. Some parts impossible to plane even with my LV la smoother. OK it might have been possible if I'd spent several hours crazy sharpening and then repeating between strokes, but I gave up and bought a Bosch ROS.Paul Chapman":3u54g8vp said:Cheshirechappie":3u54g8vp said:Karl's point about how sharp an edge needs to be for different tasks seems to me the key point.
But it's not just about sharpness. Very often it's about matching your tools and techniques to the wood. I was planing lots of Sapele today. It was horrible stuff with all the usual reversing grain. No matter what I did I couldn't get a decent finish with my normal planes - just lots of tearout and general roughness. So I got out my scraper planes (the large Veritas and small LN #212) and had a silky smooth finish in no time![]()
Cheers :wink:
Paul
Cheshirechappie":3cl48072 said:(I've never tried this, but I think you can strop an edge on the palm of your hand.
It's a question of striking a happy medium between time and effort spent sharpening and the requirements of the job in hand..........
Just what do you consider "sharp enough" to be? And how do you determine this in the work you do?
Regards from Perth
Derek
Jacob":7qsrruep said:It's sapele which set me off on the perfect planing hunt. It's not hard all over, quite the opposite in parts, and very crossed reversing grain. Some parts impossible to plane even with my LV la smoother. OK it might have been possible if I'd spent several hours crazy sharpening and then repeating between strokes, but I gave up and bought a Bosch ROS.Paul Chapman":7qsrruep said:Cheshirechappie":7qsrruep said:Karl's point about how sharp an edge needs to be for different tasks seems to me the key point.
Cheers :wink:
Paul
I might try it one day. Stanley 80 is pretty good but slow if there's a lot to do.Paul Chapman":2evet49v said:Jacob":2evet49v said:It's sapele which set me off on the perfect planing hunt. It's not hard all over, quite the opposite in parts, and very crossed reversing grain. Some parts impossible to plane even with my LV la smoother. OK it might have been possible if I'd spent several hours crazy sharpening and then repeating between strokes, but I gave up and bought a Bosch ROS.Paul Chapman":2evet49v said:...
Cheers :wink:
Paul
You should have tried a scraper plane, Jacob. No need for any crazy sharpening :wink: I've yet to find a piece of wood with difficult grain that can't be tamed with a scraper.
Cheers :wink:
Paul
Paul Chapman":3v5wjxty said:I've yet to find a piece of wood with difficult grain that can't be tamed with a scraper.
I don't put myself in that situation; I'm not insane. :roll:.....The danger of crushing timber fibres rather than severing them cleanly is an ever-present risk. Why would you wish to put yourself in this situation?
Candle wax has a similar effect, particularly on a plane. It can transform it as though freshly sharpened and set, for just a quick squiggle.St.J":dx54nz6p said:........
In short - stropping makes my paring tools seem sharper because they're polished......
St.John
Cheshirechappie":1fub9qaj said:In the 18th and 19th centuries, when the only sharpening stones readily available were the likes of Turkey, Charnley Forest and Welsh Slate, stropping on dressed leather (which was fairly cheaply and easily available) was a realistic way of quickly refining an edge. (I've never tried this, but I think you can strop an edge on the palm of your hand; seem to remember this written in one of Charles Hayward's many books.) Now that the technology of sharpening has developed, it would be surprising if no better method of achieving a very fine edge than stropping had been developed. However, that doesn't mean that stropping is dead - it quite plainly worked very well for many craftsmen over several generations, and much fine work was done by them to prove the point; so it will still work just as well.
As were/are many others.David C":288aadiu said:........I have a black "surgical" Arkansas stone. It's too fine for woodwork purposes. Probably why it's termed "surgical".
Arkansas stones were highly prized by cabinetmakers for more than a hundred years.
David
Reality check - Arkansas stone was introduced in the paleozoic era, stropping (and sharpening) has been going on since the paleolithic.bugbear":iqbh4szd said:Cheshirechappie":iqbh4szd said:In the 18th and 19th centuries, when the only sharpening stones readily available were the likes of Turkey, Charnley Forest and Welsh Slate, stropping on dressed leather (which was fairly cheaply and easily available) was a realistic way of quickly refining an edge. (I've never tried this, but I think you can strop an edge on the palm of your hand; seem to remember this written in one of Charles Hayward's many books.) Now that the technology of sharpening has developed, it would be surprising if no better method of achieving a very fine edge than stropping had been developed. However, that doesn't mean that stropping is dead - it quite plainly worked very well for many craftsmen over several generations, and much fine work was done by them to prove the point; so it will still work just as well.
Absolutely - the historical use of stropping exists in a context where Arkansas, let alone waterstones hadn't been introduced. Even when Ark stones were available they were hugely more expensive than a strop.
And for carvers, a slightly yielding strop is ideal for the many curved gouge edges involved.
BugBear
Jacob":10mkeyw7 said:Reality check - Arkansas stone was introduced in the paleozoic era, stropping (and sharpening) has been going on since the paleolithic.
