Philly
Hi All,
As most of my tools are in storage I hit a problem when edge jointing some boards for a table top. Some of the boards had edges that were in wind. And I only had my LA Jack and a block plane to hand. My LA Jack has a straight sharpened blade (with the corners knocked off) so was no good for my usual (Charlesworth method) means of removing wind. So I came up with this….
Using a square mark out the areas that need removing on the edge. Then using a block plane remove the high spots with partial (i.e not full edge width) shavings. A full shaving from my LA Jack gave a true edge. Result!
Maybe not the best way to work but it worked!
Hope this is of help
Philly
Who really, really wants to move into his new workshop
Philly
