rhrwilliams
Thanks for reply / info Mike
Never seen a DT in old work so never used it. Always a simple bridle pinned through.rhrwilliams":1o8000lz said:....
1) At the meeting rail I did a dovetail type joint (taken from Cassells joinery book). I made a bit of a hash of this , is there an easier joint that can be used ?
By hand always - everything always marked up from the rod so I'd just follow the marks. After marking up ALL the components for all the windows (could be a lot of bits!) you are on autopilot just obeying the marks and hoping it'll come out right!2) I scribed everything on the spindle moulder and hoped it all fitted together later - it did mostly but was not micro mm perfect. Do most people do this on spindle or scribe by hand ? The profile I used was a complicated one and I think an Ovolo or something may be easier to scribe by hand. I can see that doing it by hand has some advantages.
3mm total (1.5 gap each side) so a £1 coin would be about right for offsetting the staff beads as you nail them in. The gap from back of stiles to the pulley stiles can be more3) What tolerance do you allow between sash / box frame for sliding and between sash / staff beads ? I left 1.5mm but this feels tight still.
Usual squaring up procedure is to check the diagonals with a lath - nail in one end as a pivot, marks at the other. Use sash cramps to pull it straight. Front linings glued and nailed, back linings nailed only and removed for fitting, then nailed glued4) I had real trouble squaring the box frame up - does it hold together square when you glue linings on, or do you rely on wedging it square in the opening ? Also do you make up the box frame on the bench or glue and pin the linings on when its in the opening ?
Sounds OK but many variations - basically bigger means thicker5) What stock thickness is generally used ? I used 22mm for box frame, 15mm for external linings and 18mm internal linings. I was thinking 15mm may be too thin for external linings.
If they well made and well fitted they are draught proof enough and anything extra just makes life complicated - moisture traps, paint problems, stiff movement etc.6) If I want to draft proof sashes, so I need to alter construction at all at this stage ?
Scribing - you cut at 45º then saw out the profile (or gouge etc). Or pencil in a line sighting with combi square at 45º and follow that. Easy to say difficult to describe!rhrwilliams":qc13qnd5 said:Also I did another sash which had a simple ovolo and scribed it by hand .... I've got the hang of it now and it's not such a difficult task as I thought .
Thanks for all the help . Very much appreciated
