Drive Centre - which type?
Andy's Shed
13 Aug 2022
York
I've just fitted a new headstock spindle and it takes an MT2 drive centre, the one that I currently have from the old spindle is a basic 4 prong MT1 version.
I was thinking of ordering a 4 prong MT2 centre, but having looked online there seem to be various types available. I don't want to spend a lot if possible.
Any recommendations?
There is another type of drive you might want to consider. They are called safe drives or ring friction drives. They look like the Steb centre without the teeth or the same as the cup centres used before bearing centres for the tailstock before came along. They have the advantage of slipping if you get a catch and don't chew up the wood when it slips. They reduce the pucker factor when learning or during a momentary lapse in concentration.
https://www.axminstertools.com/global/axminster-cone-friction-drive-2mt-340126
https://www.ebay.co.uk/itm/311777258203
https://oneway.ca/index.php?route=product/category&path=59_75_107_121
I always felt the need to drill a hole to fit the 4prong drive into to make sure there was enough contact, much prefer my crown drive, the teeth dig in and grip perfectly and it fits in my chuck jaws if I can't be arsed to take the chuck off.
A morse taper drive centre can be held in a wood turning chuck & removed quickly when no longer required. A lot of professional turners do this.
The prongs on drive centres should be kept sharp using a fine file. The centre point can be touched up by carefully using a small flat file used in line with the bed & at an angle so as to keep out of the way of the revolving prongs.
Pucker factor made me grin, not heard that before. Certainly experienced it a few times though :ROFLMAO:
Think about what you will be turning. Recently I started turning small things from 50mm or smaller square spindles, my original drive was far too chunky so I got myself a smaller one. There may be more than one right answer.
I have been using a pair of these for a while now. For smaller work, they are great.
