Those Record stands are probably the best that I've seen at our end of the market. Is it worth scouring eBay for a second-hand model?
A few years ago, I bought a Wolfcraft drillstand via. eBay on the back of glowing comments in one of the magazines and I only got round to using it for the first time this week! :shock: I can't get the link to work but, you'll find it on eBay as the "
Wolfcraft 4522 Tec Mobil Drill Stand". Yes, I have been using it to drill holes in my 'bench top too, with my Metabo SDS drill. :wink: It's not a bad piece of kit, although if you apply too much downward force then it's easy to drill slightly off vertical. I also find it hard to know when you've actually hit the depth stop. If you push too hard then, you can also move it. :? (I'm pleased to say I payed less than £20 for mine, including postage! 8))
I doubt that the Record models suffer from most of these problems. Looking on eBay, Wolcraft appear to do other models as well.
What drill bit are you thinking of using? Only, I've been struggling with a ¾" forstner from Wealden - they clog up very quickly and then begin to burn easily; very frustrating! They're really best for shallow, stopped holes. Flat bits do cut much faster and also clear the waste away but, they're quite wild and can very easily make a mess.
I've noticed that Wealden do 20mm diameter lip and spur bits for less than £10 - I may buy one of those... :roll: My only concern here is that a marginally over-sized hole (20mm) may affect the Veritas accessories (dogs and clamps), which all have ¾" shanks? It's probably nothing to worry about though...?
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
