John Hall
Bosch Hex9 are quite good and have hex shanks as you say…for what purpose do you particularly want hex shafts?…
And what bits would be recommended for this driver please? Milwaukee‘s own shockwave series perhaps? Or are there any generic makes that can be recommended?Or get yourself a Milwaukee Fuel impact driver - there is a non impact setting on them.![]()
Thought hex shanks were designed for impact drivers?I find the hex mounted drills a bit wobbly when used in an impact driver.....
but sometimes who cares.....
except for hand brace, traditional, they are quick and do a great job in furniture making. I still use mine a fair bit, much quicker for a few one off holes. BUT agree for power tools or the drill press best to use brad point, especially if churning out dozens of holescannot agree more, you lose all control over the feed in as it just wants to take off.
brad point come into their own as the size goes up or if need to preserve the surface, dowling etc. For small screws HSS is fine.I've spent 50 + years not using any other for smaller holes in wood. Lip and spurs may well be better better but for 99% of uses decent ones aren't worth the price premium, and poor quality ones are not worth the metal they're made of.
Yes the old handbrace with those square shanked bits, makes me value cordless drills a lot more because prior to them using one of those brace & bits to cut holes through joist for cable runs was hard work, half a turn and back on the rachet but there was nothing to go wrong or battery to go flat. Joist in those days were more substantial and could be drilled unlike the matchsticks used now.except for hand brace, traditional, they are quick and do a great job in furniture making
YepHex shank as in ones for an impact driver?
I'm a carpenter and sometimes i have to do the odd little quick job where i might only need to drill a few holes and pop a few screws in, but you still end up dragging lots of bits if kit inBosch Hex9 are quite good and have hex shanks as you say…for what purpose do you particularly want hex shafts?…
Sounds like a DTD170 - I got the next one after that, the DTD171 with more speeds and more bells and whistles about 2-1/2 years back (in boring old teal) which Makita replaced with the DTD172 last year in Japan. I was working with a guy who got one of those in metallic copper. Blingy! How do you find it getting on with the Japanese hyroglyphs on the control panels?In the bottom of the pik you can see a bright green impact, its a sub compact japanese makita ( they release new models over there first and even after import tax etc, its cheaper than uk kit. )
Its about 3 years old now. Its got settings for 3 speeds and a setting for putting in the tek screws
The only type i have are the quality ones i use on my bikes, i would use the free stuff, it usually goes straight in the bin.I find it helps if you don't use the Trend hex key and instead use a decent one
