Phil Pascoe
The jaws don't necessarily centre properly when gripping the helix. That's what I've found, anyway.
It is simply because the fluted part is necessarily weaker that the solid part, and so more likely to bend. A stub drill will typically only have maybe 2 times it's diameter of flutes, the rest being smooth.why is it more accurate to cut down the tip than the shaft? I would have assumed that a factory machined tip would be be more accurate than a home sharpened tip, so better to reduce the shaft where accuracy is not important.
I can only think that reducing the shaft would leave the chuck gripping onto the grooves / auger rather than a smooth shaft which could introduce error, am I on the right grounds??
I wonder whether a collar (with an opening / gap down one side to allow for tightening) down the length of the bit would give the extra bit of support needed
Not very likely.That would require a rigid drill bit rotating eccentrically and the tip of a 2mm drill bit isn't connected immovably to the shank.What usually happens is that the rotation continues and the flexing of the bit with each revolution leads to a breakage.So if it has a run out, you drill a 2mm hole it ends up 2.2mm ?
