Chris Needham
Slightly sidestepping my original question, last year i was working on an old property and when drilling into walls, my masonry bit occasionally slipped as it naturally found the weak spot in the old brickwork so the hole ended up a few mm off target. I was able to resolve the issue by using a wooden plug so no drama in the end. I then borrowed a friend‘s SDS drill for the remaining work.
No doubt you have more experience then I in such matters, would you agree that an SDS drill was my best option for my predicament at the time?
And one other if I may, is there a failsafe way to size match rawl plugs to bit sizes? Thanks again.
