Dremel 4000 v dremel 4250
Niall Church
22 Apr 2023
Hi, Anyone know the differences between Dremel 4000 and Dremel 4250?
I know there are different kits,I'm just interested in the machine itself
i looked into a lot of dremels comparisons in 2021 and 2022
and a lot of sites an youtube videos
in the end the 4000 Kit went on offer at amazon from around £189.99 down to about £132 - that decided me simply the price
I have used mine a few times and its been fine
https://www.amazon.co.uk/gp/product/B007651OPW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
https://www.dremel.com/au/en/p/drem...l 4250 runs cooler and,with EZ Lock Nose Cap.
Dremel 4250 runs cooler and has lower noise (compared to Dremel 4000 and 4300) making sure that you enjoy all types of DIY projects. While you are changing your accessories you don’t need to waste time looking for your wrench. Dremel 4250 comes with EZ Lock Nose Cap.
I also got a small multi chuck, multi vice, drill press, router attachment, and separate big box of bits , guard - also all on offer
from amazon
All for under the orginal price just for the kit - watched the price for a long while
I was looking at the cordless , but wanted at least 2 batteries and was not on offer
I also considered alternatives, watached a lot of videos , BUT ot was the price that decided in the end
from amazon
That's the one I'm looking at,with all that kit,looks a good price it's 157 quid at the moment,can parts be had for the 4000,as I think it's discontinued?
Sorry no idea, if parts are available, to be honest if mine failed, i would probably just get a replacement dremmell as all the kit will still fit
someone elkse may know , but if failed in 3-4years who knows if the part will be available then
I went for a cordless and have appreciated the lack of a cable on many occasions. I've got an aftermarket 2nd battery which seems fine.
Brian
Took the plunge and ordered it for 157quid,so, I'll have a look when it arrives!
I was fortunate to win the 8260 platinum kit in Dremels Christmas giveaway on instagram last year, haven managed to use it yet but I've also got a dremel from way back when I was a teenager in 1993 and it still works.
The dremel 3000 type 1?
So, it's nearly a year old,and you haven't used it yet!
@Niall Church this one
The only problem I have with it is a possible break in the cable causing it to cut out now and then.
By the time I actually received it I think is was getting close to Easter so only actually had it about 7 months, I've no space for it in the makerspace yet so it's still in the house, plus I've not had cause to use it yet but do plan to do some pierced work on some turnings at some point next year now that I'm getting the makerspace laid out how I want it.
Looks very similar to the one I have Dremel 3000 type 1! The coupling inside has perished so,I think I can get one on ebay,as dremel don't have that part anymore!
Here's my first Dremel,and inside uou can see where the coupling was to drive the shaft!
    1.2 MB
    807.7 KB
One of the best things I have for mine is the right angle drive adaptor, very useful for getting into awkward spaces. It doesn't look very substantial, but I have given it some hard work and it is still as good as new. The quick clic cutting wheels are good too.
so as i say i went a bit mad, as some on offer at the time and purchased some later
vice - used this a lot - and for other DIY work
https://www.amazon.co.uk/gp/product/B000QG79ZW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Drill Stand - used once to drill a few small holes in some metal
https://www.amazon.co.uk/gp/product/B0012RQG94/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Router plunge - used once to make a slot in a small piece of wood
https://www.amazon.co.uk/gp/product/B0009EQ5QA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Router Bits
https://www.amazon.co.uk/gp/product/B00MOIFXA8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Multi Chuck, not used - thought might be useful - purchased later
https://www.amazon.co.uk/gp/product/B0002SMMY2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Cover - i got this after i used the dremel to sharpen a lawnmower blade - 18" - sparkes went every where , so thouth may reduce that , still wear glasses - NOTE only 1 , picture sort of shows there maybe 2 which i thought
https://www.amazon.co.uk/gp/product/B0779TNBFS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Then i thought , i would get this kit of bits - as i was sure i would want somethign not in the main kit and sure enough i have used a few bits from this kit
Rotary Tool Accessories Kit
https://www.amazon.co.uk/gp/product/B0928XXDRP/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Most of it was purchased at the same time , as i got a big discount from amazon at the time
hope you enjoy , part of my decision was the box, i have stuff in those plastic pressed cases things - and they never seem to last , i thought the BOX was good to have for the kit
I have been using an old mains power one on clock cases and polishing up small parts, then I saw the battery model advertised with a spare battery so got that and find it better to use than the MP one, and when I needed to use a small router cutter I made a frame to fit the Dremel, I ordered some springs for the bars and it took six weeks you guessed it from China, I had done my job and put it away till next time before I got the springs.
Router Bits
Yes,the case caught my eye as well! Have you used the flexi adaptor?
