lastminute
..my kitchen downlighters need replacing...currently 240v 35w...is it ok to replace them with 50w type or keep to 35w?
Thanks...Gerry
Thanks...Gerry
Beanwood":2ie4cgmh said:How do you all manage to get exactly the same looking light when replacing a failed LED. In our kitchen there are 8 downlights, so a pack of 10 provides 2 spares, but once they were used, with so many suppliers, power and colour combinations I find it really hard to find a match that doesn't stand out like a sore thumb. I ended up changing the lot, and keeping the good bulbs to use where only a couple are together?
Arron":1oq60g30 said:Beanwood":1oq60g30 said:How do you all manage to get exactly the same looking light when replacing a failed LED. In our kitchen there are 8 downlights, so a pack of 10 provides 2 spares, but once they were used, with so many suppliers, power and colour combinations I find it really hard to find a match that doesn't stand out like a sore thumb. I ended up changing the lot, and keeping the good bulbs to use where only a couple are together?
The bulb that needs replacing should have all the info you need.
Colour (warm white/cool white)
Lumens
Watts
Match all those numbers up and you will have a direct replacement
Arron":tbkp9ulk said:The bulb that needs replacing should have all the info you need.
Lumens
Watts
