I have just received my dowel plate Steve, thanks for a quick delivery! Very happy with it.
Yes i did that too rather than whack it through. worked a treat.Sometimes you get better results if you don't hammer the dowels through the plate, rather 'drill' them through.
For 10mm dowel I cut some square blanks roughly 15x15, rounded an inch of one end (I used a belt sander), put that in the drill and 'drilled' the rod through the plate. After it had gone through the 10mm hole, I left it in the drill and spun it whilst running some 120g sandpaper up and down it - finish was great.
One 10mm, and one 8mm
Long shot… very long shot….do u still have these available???View attachment 141280
I've sold a few of these - made from cnc'd 6mm mild steel - £15+p&p ....... so £20 all in.
Think I may still have a couple in the shed.
Thanks , look forward to hearing from you, happy to send you the money now if you let me have your preferred payment details.I don't have any here, but I can knock you up one when I'm back at work in the New Year.
I'll message you when it's done
(They're now £20+p&p - £25 all in)
Always done this with the odd dowel I've wanted. Bought standard sized dowels in. They're cheap enough. A visit to most engineering type places will get you a suitable offcut of steel, often for free. The last time I asked at a local place, I was just told to help myself from the scrap bin.On the grounds that wood tends to be softer than steel I use normal black steel drill the hole to the size of dowel I need to make and use a stepped drill or conical grinder to open out one side of the hole for clearance -it's quick and it's great for one-offs
That’s great, thank you! DM me some payment details whenever you’re ready. Much appreciated!I'm more than happy to make you one Mark - I'll be back at work in the new year, I'll let you know when it's ready.
Dowel plate arrived today as promised, very happy with the quality,can’t wait to give it a try.Thanks , look forward to hearing from you, happy to send you the money now if you let me have your preferred payment details.
