I have just received my dowel plate Steve, thanks for a quick delivery! Very happy with it.
Yes i did that too rather than whack it through. worked a treat.Sometimes you get better results if you don't hammer the dowels through the plate, rather 'drill' them through.
For 10mm dowel I cut some square blanks roughly 15x15, rounded an inch of one end (I used a belt sander), put that in the drill and 'drilled' the rod through the plate. After it had gone through the 10mm hole, I left it in the drill and spun it whilst running some 120g sandpaper up and down it - finish was great.
One 10mm, and one 8mm
