Could easily and accurately throw that comment right back at you! What you think you said is interesting others see as utter opinionated tosh. :lol:Jacob said:
the problem is with the gollums like yourself who have nothing interesting or useful to say on so many topics but instead turn their attention to attacking other posters.
Don't need to, Mike has effectively ripped you to shreds, and done it in a much more polite way than others would have, some of us who've been in the building trade and have a little experience of that subject could have contributed but have the good grace to accept that the expert knows what he's talking about rather than pontificate and contradict the guy at every turn - I wonder who did that? Oh yes it was you - AGAIN!non of our gollums have attempted to make the slightest comment or contribution to anything else in this thread (and many others), presumably because you having nothing useful or interesting to say, as usual.
Oh dear, has little diddums spat his dummy out again, poor little chap. :wink:If you don't want to have a conversation revolving around me then don't keep f****g starting them and winding them up, you tedious boring twerps.
Nor me. :lol:thomashenry":132taegu said:I don't think Jacob was 'ripped to shreds' at all. I'm still unsure what he's meant to have been wrong about.
Reduces heat input required by conserving heat from when the sun was out, or other source such as ground heat pump, and releasing it slowly, or on demand in controlled systems. Or in the case of bio mass boiler it conserves the heat from the boiler working efficiently at full blast but producing more heat than can be used immediately. A buffer, in other words. It's simple in principle, but not necessarily in practice.John Brown":hcnl1ozd said:......
If I assume no sun, and an outside temperature lower than the desired inside temperature, then my tiny brain cannot fathom how thermal mass can reduce heat input. This would be tantamount to free energy, would it not?......
Jacob":2i64t2t3 said:Nor me. :lol:thomashenry":2i64t2t3 said:I don't think Jacob was 'ripped to shreds' at all. I'm still unsure what he's meant to have been wrong about.
Right I see what you mean. Presumably the heavy solid construction would conserve heat and buffer the rate of heating up and cooling down. The light weight would heat up quickly and cool down quickly. Not sure what this shows as in the real world you'd simply adjust the source - full blast in a cold room, which would have to stay on longer to heat up a thermal store build, which would then take longer to cool down. Not net gain or loss. Nor would there be with thermostatically controlled bulbs - just automatic adjustment instead.John Brown":m5kd1xtn said:Those points, Jacob, are irelevant to the conditions I proposed. i.e. no sun.
And MikeG's thermostatically controlled lightbulb in a box thought-experiment has nowt to do with biomass, ground source or any other surplus heat scenario.
My questions were really aimed at MikeG, but I guess he's abandoned this thread now, which doesn't surprise me.
Still seems to me a zero sum game. The concrete box will take longer to heat up (take up more energy to reach the thermostat setting) but longer to cool down.Build yourself two boxes in the garden, each 1 metre cubed. Build one of plywood, 100mm Celotex, plywood....all round. Build the other of 100mm cast concrete, with 100mm Celotex externally, with ply cladding. Put a thermostatically controlled 100W incandescent light bulb inside both as a heat source, and monitor the energy use for a year. .....
Do you?Lons":19j6x7c1 said:Jacob":19j6x7c1 said:Nor me. :lol:thomashenry":19j6x7c1 said:I don't think Jacob was 'ripped to shreds' at all. I'm still unsure what he's meant to have been wrong about.
No surprise there then :wink: :lol:
scooby":21hxuuhw said:I'd never even heard of trombe wall before this...
thomashenry":3vpg49ta said:... I'm still unsure what he's meant to have been wrong about.
thomashenry":1do6iib8 said:Do you?Lons":1do6iib8 said:No surprise there then :wink: :lol:
No you haven't quite got it. A "Trombe" wall is a substantial structure with a high specific heat (capacity) sited behind glass to slowly absorb heat from the sun and release it slowly even after the sun has gone in.Benchwayze":16mb4nqa said:......
Okay then; I Googled Trombe Walls and now I probably know as much about them as does Jacob. ...
Er, what joke? Must have missed it!Benchwayze":2qmnz6sp said:Still can't take a little joke then Jacob?....
