LBCarpentry
I had to stop and think about thatIt's better to regret something you have done than something you haven't.
I think you've got it. Permanent set, alternatively called compression set in table tops (for instance) is usually something that develops over quite a long period, sometimes a very long period and caused by moisture cycling. Not every panel experiences moisture cycling to any significant degree, and are therefore such panels are much less affected.As i read what you've said Richard, is that they way a table top is looked after in terms of cleaning/care etc has a much more influential impact than the rings natural tendency to try to flatten as in a free standing board/plank. This being due to the locking in position of the the parts in a piece of furniture. Am I interpreting correctly then that groth ring orientation then is basically immaterial in the tops construction?
