How did she get an Aga into a small kitchen?![]()
It's Ireland.
As a green party voter since 1985, i know thatis
confused now, do smiles get happier or sadder as they dry (if you follow my thinking)@JoshD i think you have unfortunately got yourself mixed up. The reason for cupping is that the radial stresses within a tree are basically trying to get the growth rings of a processed piece of wood to straighten out flat. Therefore, if you have a board laid as you describe ie the growth rings look like a U, then as they equalise the edges will be forced down and you eventually will have a hump in the middle. The obverse being the case when the growth rings are orientated like an n. hence why we try to have 1/4 cut straight grain blanks for planes etc.
I may be misreading what you've written, if so apologies .
Genuine interest why should you put poly over Danish oil? I thought they were different bases???I m still a Danish oil person after all these years.
I believe that oiling all round seals the wood and protects from moisture ingress. Oil solids or micro balloons?
I know myself that that is probably incorrect but to date I have never experienced an explosion from anything I've made where the base timber could have held moisture.
But, I do rough plane then bring the wood inside, placed underneath beds to aclimatise for long periods of time.
I use Ronseal poly on table surfaces protection on top of Danish oil, again after a longish drying out time between the two applications. Only on the show face.
... and may also be influenced by ...? See section 7.14?The reason for cupping is ...,
Cheers James
Here's something else to think about: a table top seems to dry out more on the topside, especially if exposed to the sun, than the shaded underside, and so the edges are likely to cup upwards. I've done some tops cut from full width slabs and I've made sure that the growth rings are curved side down: if dried uniformly this will tend to result in edges cupping downwards, so counteracts the differential drying of top and bottom. I'm wondering if in extreme cases it would also be worth leaving the bottom unfinished.
I seem to remember reading somewhere that as the seat dries out, it grips the spindles tighter, and that the ends of the spindles were often slightly bulbous to take further advantage of this.I've always wondered how making spindleback chairs from green wood don't fall apart when brought inside?
Or do they?
