Do you 'sign' your work? If so how?
redmoorphil":10nluew8 said:
I find a little corner and draw a small spiders web with a spider dangling from it.
Started to do it on toys years ago to add some illustration to them and it just stuck.
.. nice touch..would it be rude to call it a doodle?.. I like doodling & doodles ...what do you use?
I only make things for friends and family and like the idea of leaving my mark when I shuffle off. At the moment, until I retire or get the sack, I have access to a laser cutter and so use little hardwood discs to label my stuff:
But in the long term I will need some other way of marking my things. Do you think it would be possible to use a metal stamp to brand a mark onto a piece?
Simon
Saint Simon":1b3umhme said:
...... I have access to a laser cutter and so use little hardwood discs to label my stuff:
Simon
Ooooh I do like that hardwood disc. Love the idea of the initials and date. That's how I would like to do mine, sadly no access to a laser cutter, so wonder if there is another way of doing this? What wood have you used for the disc?
See previous posts about Chalco who make metal stamps.
I think the wood I am using at the moment is just an ash offcut about 3-4mm thick. In the longer term I wondered whether I could achieve pretty much the same effect with a metal stamp that could be heated.
Simon
Simon
Not sure you can create the same effect with a metal stamp .... see images earlier in this thread. They don't appear the same as your laser cut wood and you would need to get a new one each year if you want to continue with the date!
woodbloke":3hokvgbq said:
I recently had stamp made at Chalco:
...they work best on end grain though - Rob
I found that you need to clean all the debris and crud out of nooks and crannies with something like a pin...the Chalco stamps then seem to work better on long grain, but there's still an element of fibre 'crushing.' It's also quite important to get the right amount of 'thump' with decent sized maul, a small toffee hammer won't do the job - Rob
Most of my work is turned, and I pyrography a sigil, the year, and the type of wood on the base of the piece. I've done this on the underside of any furniture I've made as well. The only things I don't sign are the craft tools (crochet hooks, knitting pins, drop spindles etc) and small gift items (light pulls, dibbers, honey dippers etc) - mainly because there isn't room on the piece or a hidden spot to do this. Unsigned items usually have a tag tied on them displaying the type of wood.
woodbloke":33f6vnfh said:
wcndave":33f6vnfh said:
What kind of person wants or needs to stamp a 400kg wild animal?
http://www.spanglefish.com/metalstamps/index.asp?pageid=358140
All you need to do is to submit a pic vial email of the sort of thing you're after and Ian will give you a quote...dead easy to do - Rob
Heh, think you missed what I was looking at...
The question always arises unfortunatly there is no set charge
You may want to stamp a musical instruments or a 10 foot bear
We have made stamps for both
just wondered who needed to stamp a very large bear!
