Krysstel":1843wabs said:This set up obviously works since we can all see the evidence, but surely it must be a bit messy emptying the box ?
How does it handle chips from a PT ?
Mark
A deflection plate that, well, deflects. Anything - air, dust, water.TrimTheKing":1n6fprqy said:Advance apologies for being an idiot, but what is a baffle, and what does it do?![]()
Mark
Thanks Mike.Mike Garnham":pveh5trt said:Mark(s),
a baffle is just a bit of wood that disturbs the airflow, or causes it to change direction.
The upper baffle is just a loose-fitted piece of wood with dozens of holes (c. 10mm) which goes the full depth of the box.It seems to stop the finer dust from going to the vacuum cleaner. As you can see, it piles up in front of the baffle. There is another baffle with holes at 45 degrees in the corner below the shelf.
Don't get too hung up on this design. My other one is quite different.......the principle is to make the air travel a long and circuitous route through the box, and almost any design doing this will work. I should have patented this 15 years ago when I dreamed it up........I could be retired to my workshop by now on the proceeds!!!!
Mike
Absolutely, looks good to me, I might have to give it a crack when I am off next week.Mike Garnham":14sxtt76 said:Mark,
This box has an immeasurably small impact on the suction. If you take the hose direct from the vacuum cleaner, it will hold up a piece of ply of size X. Then re-connect the cleaner to the box, and using the hose from the box, it will hold the same piece of ply. I loaded it all up and tested it to its limits when I first made the thing, and I couldn't measure any difference between the two.
A member here, Derek Willis (I haven't seen anything from him in a while???), saw this design and made one of his own last year. He now swears by it. The thing is, it is so simple that you can make one in an hour out of scrap. That isn't a big risk!!
Mike
Do you have any students near you???wobblycogs":2n1o7yed said:Purely out of idle curiosity, how much does a traffic cone cost and where do you buy them?
You know, I never realised until now that Camvac are just a few miles from me.johnf":3p7oip8p said:I just use one of these On a dustbin works a treat I haven't emptied the bag on the chip collector in six months
http://www.camvac.co.uk/images/accessor ... 50-118.jpg
What your design and those found here and here demonstrate quite clearly is that a simple approach can, in practical terms, give almost as much performance as the most highly designed solutions. The law of diminishing returns is quite graphically demonstrated.Mike Garnham":3ufyihud said:I promised pictures........
Obviously top......closed, bottom........open for dust removal.
This is the small one for my bench, but I have another over the other side of the workshop for some of the other tools which is a different shape but exactly the same principle. There is absolutely no need whatsoever for a cone or cyclone-effect .......simply create a long path for the air to get through a box, and it will drop its dust load.
One day I will make a room-sized version hooked up to a network of rainwater downpipes to all the machines.
Mike
wizer":2h739vsu said:I changed Henry's bag today... 3 weeks since it's last change! I'm looking into this one.
wobblycogs":167sls78 said:Purely out of idle curiosity, how much does a traffic cone cost and where do you buy them?
woodbloke":2ambqpn1 said:Mike - a request. Could we have a couple more pics please of the internal gubbins?..holes etc. All is not too clear from your current pics - Rob
