Disston help
nitram55
26 Aug 2007
Tamworth W.Mids
Hi all
I have inherited what appears to be a Disston D8 rip saw (26 inches 6 ppi) from my mates dad, it is a bit the worse for wear and I would like to put it back into commission.
however it has a curve set in the blade as below.
What i would like to know is can this be fixed and if not will the saw still be of use.
Any advice will be gratefully received as I am a complete novice when it comes to 'proper' saws.
Martin
nitram55":ocqfqehr said:
Hi all
Martin
Ah hah. That's a "curve" not a "kink". Kinks are hard. Curves can be ameliorated by simply bending the other way, being CAREFUL not to introduce a kink at the pivot.
Happily, minor curves in handsaws are not a practical problem in use.
BugBear
nitram55":1ktxllws said:
However it has a curve set in the blade as below.
Hi Martin, welcome to the forum from another newbie.
Not sure if you mean, that there is a curve in the blade (in this case follow bb's advise). The impression from the picture makes me think, that setting of the saw is wrong (to much set on the left side), and thats why you are sawing a curve :?:
In the last case, you can reduce set by stoning or give more set with a saw set (eclipse 77).
Cheers Pedder
Thanks for your replies, with some judicious bending the saw is now a lot straigter.
Now for the black art of sharpening :? .
Martin
Martin
Not so black - there are plenty of good articles on the net. Try here first:
http://www.vintagesaws.com/cgi-bin/fram ... sharp.html
Another good one is this:
http://norsewoodsmith.com/node/87
Then work your way through Cian Perez's links on saw sharpening and you will be full of all the gen you need (and more):
http://www.cianperez.com/Wood/WoodDocs/ ... How_To.htm
Cheers and have fun.
