TominDales
You are right to highlight the potential 'unexpected consequences of new tech' such has heat pumps, solar panels, electric cars. Its happened before, CFCs were introduced to remove toxic materials like ammonia in refrigeration, compact fluorescent lamps replaced icandecent lamps but contained mercury (current LEDs are benign, although some of the early ones contained cadmium phosphors). Industry has learned from this history and legacy, modern products are more carefully assessed for environmental harm and European legislation under REACH and other stringent regulations requre extensive research into SHE before a new product is introduced into the marketPlastic is terrible stuff, made from fossil fuel, does not biodegrade, and in most cases there are a much more environmentally friendly alternatives. When those ground source heat pump fields have passed their useful life, is someone going to dig all that plastic pipe up and dispose of it properly? Nope, they'll just trench through it and lay some more. It amazes me how much environmental damage people are willing to do to save some carbon. Like the all the nasties used in the manufacture of solar panels, or electric car batteries, and the cost to the environment to make them. And when those solar panels and batteries die, what are they going to do with them?
The drive for 'environmentally friendly products has caused industry to do far more due diligence on its supply chain with life cycle analysis. Its pointless developing and selling an EVcar as greener product if its made unsustainably or leads to pollution. Car companies are requiring analysis of the raw materials and the energy that goes into new batteries, hence the recent announcement by JM that there Polish battery plant will use renewable energy.
Its also why the latest generation of batteries are low in cobalt as mining from the DRC is problematic and why recycling of batteries is already being planned. They are virtually 100% recyclable with valuable metals to extract.
Wind turbines are difficult to recycle, the industry is carrying out extensive R&D on how to do it as it does not want to tarnish its reputation when turbines come to be decommissioned en mass. PV cells are are quite recyclable, they last a long time - design life of 25 to 40 years,the glass, silicon, metal can be recovered. A bigger issue right now is throw away electronics, phones, TVs etc.
Its too much of a generalization to say plastic is terrible stuff.
I know we are woodworkers, but we have to acknowledge that plastic has hundreds of uses, most of which are essential to health and wellbeing. The problem with plastic, is its cheap to make and so useful that it has become ubiquitous. Most applications don't cause a problem, the real issues with single use plastic getting into the environment.
Plastic is essential for medical and healthcare and for preserving food, so its a vital resource.
In terms of pipes, that is a very good use of plastics, they require little energy to make as they are made at low temperatures, the require little energy in the application and they last for a very long time.
The latest Underground PVC water pipes and pipes for heat pumps have a design life of up to 100 years, it has crept up from 40 years to 70 and now 100 years in use. It has a very low carbon footprint. See bellow for the relative emissions of different uses and industrial materials.
The highest emissions is space heating of buildings, that is why there is pressure to ban coal, gas and oil heating. Transportation is the next single biggest emitter of CO2, which is why electric cars are so high a priority. When its comes to industrial processes, cement and steel are the big emitters, both of which will be hard to change as carbon is integral to the manufacturing process. There are experiments steel mills trialling use hydrogen to reduced iron oxide (replacing coke) and there is research into low carbon concrete - a very tough nut to crack. Plastics represent 2% of CO2 emissions ( 5% of 36%), less than paper, so its lower down the priority list, however zero net carbon plastics are being researched, also plastics are theoretically almost 100% recyclable, its down to economic and structural reasons why only 9% is recycled. Glass is contained in the other box, but that has a higher carbon foot print than plastic.
The biggest problem with plastics, is not that they come from fossil fuels, but from pollution by discarded plastic. This is a priority in the UK with Unilever and P&G leading the research and engineering efforts to eliminate single use plastic - a plastic packaging research centre has been established on the Wirral to lead this work. Its an absolute scandle that plastic is being flushed into rivers globally and the sooner the industry eliminates it the better in my view. However solutions to several health/medical/food application are needed or we will see an uptick in illness and food shortages.
As for our plastic pipes in a heat pump. Provided they are left in the ground they will come to no harm, they should last 50 to 100 years and could be extracted and recycled if need be.
