Jigsaws don't cut square. It doesn't matter which model, how used, or which blades, the cut wanders off square.
It's a fact.
The only answer is a router.
It's a fact.
That tends to be my experience in material over 12 to 18mm thick, they just don't like cutting perpendicular but then they were designed to cut curves. If I get a need where the jigsaw is the only option then I would just buy the mafell as that with it's expensive thicker blades looks to be the only jigsaw that can cut perpendicular.Jigsaws don't cut square. It doesn't matter which model, how used, or which blades, the cut wanders off square.
Excellent advice. My jigsaw approach is the same. Anything thicker than 3/4" the jigsaw is for bulk removal only and the neat cut is done with a router. Disinterior advice (post 17) is also good but I'm not really keen on making plunge cuts in thick material with a track saw.40mm solid oak can be a handful for most jigsaws which are best not used for the final cut anyway. I've fitted hundreds of kitchens professionally and would never use a circular saw either. Jigsaw to remove the bulk of the waste then a router to finish is quick and easy. A router is so useful you should have one anyway (I have 4), look for a Lidl / Aldi version if you want cheap, they're half decent and have 3 year warranty.
If you have hand tools you could use a block plane or even a sharp chisel to straighten the cuts.
Hardwood floor, not doorDo you mean a hardwood door ? A track saw can easily cut sheet goods etc but a router can do so much more so that would be my choice
why trim it? it is covered by the sink?Could you router square and trim it with some offcuts of oak from the cut out??
I always use a circular saw on hob /sink cutouts. Turn worktop upside down straight cuts with circular saw and corners with jig saw. Id say ive done hundreds this way.Hey folks,
I hope someone can spare some advice, I am really disappointed by these cuts I have made on a kitchen counter top. I have been doing woodwork for a few months and can usually get pretty straight and precise cuts with my jig and circular saws. This is the first time I have made this type of cut inside a countertop. It's a solid wood oak counter top, 40mm thick, and this was a rectangular cutout for a stove.
I drilled a whole in each of the four corners and then used a Bosch 130 jigsaw with a T308B blade, initially I didn't use the pendulum but I noticed it was taking very long so I set the pendulum to 2. I had the impression that the jigsaw was pushing me towards the inside. Once I was done I realized that almost none of my cuts were at 90°.
Pictures of shame
View attachment 191102View attachment 191103
What did I do wrong? Is it something wrong with my jigsaw?
Is there a way I can partially correct this? Should I do a pass with my circular saw to straighten this mess or again with the jigsaw?
Any advice is greatly appreciated, especially as I will have to make a cut for the kitchen sink and then cut the corners of another counter top.
I don't have any decent handsaw, but I think it could be an idea.After you had jigsawed and it came out at the wrong angle would you have been able to straighten the cut with a handsaw?
I think that's what I will do for the sink. Usually I don't bother to turn upside down, I just put duct tape around the cut and I don't any splinters.I always use a circular saw on hob /sink cutouts. Turn worktop upside down straight cuts with circular saw and corners with jig saw. Id say ive done hundreds this way.
Thanks for the suggestions. The Bosch documentation, that I have also received from this forum, states "EXPERT Hardwood 2-side clean T308BF". What blade would you suggest? I don't see any blade that's exclusively for hardwood, all of them have a bunch of type of wood listed. Maybe the Bosch T101BF or the T308BFP? All these codes drive me crazy!According to Bosch the blades you used are suitable for softwoods up to 50mm thick, your tops are hardwood so perhaps you've used the wrong blade. In my experience a courser tooth, up-cut blade is better for cut outs in hardwood, never use pendulum action as this can cause chipping, cut slowly and let the saw cut through at its own speed without forcing it. Never use a down cut blade (as suggested) in solid wood, they will not cut satisfactorily if at all and will be very difficult to use, if not impossible.
No, no no, no... Did I say no?maybe I should try the circular saw instead and finish the corners with the jigsaw.
Thought it was for a inset cooker...why trim it? it is covered by the sink?
