It didn't say that at all. No mention of fantasy tools for fantasy woodwork.woodbrains":vzb6fdkw said:.... It was also aimed at a furniture making student, the likes that attend Barnsley or Parnham. Fine furniture done to a high level of precision in very expensive timber, where close is not good enough. .....
Fat ferret":wzpnnu8a said:Never had wheel marking gauge cause I suspect it's an expensive gimmick and the cheap wooden ones work fine never had any problems with my shaft shrinking! :shock:
Ok core tool kit for working on site cause I've come to get on with job and I will bring whatever other power tools once I know I need them.
Big claw hammer
Wee pin hammer
Hachet for skirting on uneven floor, stud work, making offcuts into kindling for customers wood burner...
Cross cut saw 7tpi spear and jackson with spare in car incase I run into a nail
Panel saw with a curve at the end to use as a floorboard saw, (shop mod)
Tenon saw.
Coping saw.
Chisels 1/4 to 1 1/4 firmers plus two bevel edged paring chisels with hoop handles fitted for cutting hinge mortices.
No 5 1/2 plane.
No 4 plane, all planes old records.
Block plane with choice of blade positions
Combi square (bacho)
Tape measure, stanley.
Pencils,
Dividers,
Levels 2' 4' and 6' stabila
Marking gauges.
Bevel.
Sparky screwdriver,
Rachet screw driver that takes cordless drill bit heads.
Cordless drill 10v bosch plus spare batery and charger
Drill bits with built in countersink, screwdriver bits all in baccy tin.
Flat bits with auger bits for special occasions.
Nail punch.
Round rasp,
Half round rasp.
File
Oiltone
WD40
G cramps.
Stapler.
Silicon gun.
All of which lives in a plywood chest 27" long which is a joy to carry upstairs! All common sizes of screw and nail plus glue and other bits and bobs in box with sds drill. Plus leather pinny, specks and lug protectors. Ready to go.
Jacob":30yrqw0h said:It didn't say that at all. No mention of fantasy tools for fantasy woodwork.woodbrains":30yrqw0h said:.... It was also aimed at a furniture making student, the likes that attend Barnsley or Parnham. Fine furniture done to a high level of precision in very expensive timber, where close is not good enough. .....
In fact it goes round the houses. And why not?woodbrains":1z7me851 said:Jacob":1z7me851 said:It didn't say that at all. No mention of fantasy tools for fantasy woodwork.woodbrains":1z7me851 said:.... It was also aimed at a furniture making student, the likes that attend Barnsley or Parnham. Fine furniture done to a high level of precision in very expensive timber, where close is not good enough. .....
Hello,
Yes, it did, absolutely. You should actually read the threads that you are (errantly) pulling to bits. But then this has always been your problem.
Mike.
woodbrains":k7yypqw1 said:Hello,
The point of the thread over there, was to ascertain a core tool kit, which will be such a vital part of the tool kit, the best available should be bought. Not a 'it works with lots of fettling' or 'will do in a pinch till something more suitable is available' tool kit. A once only buy, forever kit, that will last and never disappoint. It was also aimed at a furniture making student, the likes that attend Barnsley or Parnham. Fine furniture done to a high level of precision in very expensive timber, where close is not good enough. The best tools will allow that student to reliably do this, wihthout worrying that the tools might be letting the side down a bit. So, someone who pays to go to these colleges will not be worried about a plane that cost £300 or a marking gauge for £30. Or chisels that have thick lands so dovetailing will be difficult (overcuts and brused corners totally out of the question) sharpening will be done to much higher levels of fineness that double sided India stones, and squares will be the best Moore and Wright or Starrett combination sets, not a bit of wood with a blade jammed into it. It is a 'best of' tool kit, not a DIY's under the stairs for emergency kit. It has to be contextualised; a core kit for a desert island survival would probably include an axe. A fine furniture makers kit definitely would not.
Incidentally, Stanley made wheel marking gauges with Sweetheart branding, ie pre war. Is that not trad enough?
Mike.
Jacob":1svjakcs said:Sorry if I sound know-it-all but the "new woodworkers" are so assertive about how things should be done and with what tools, that you have to be fairly emphatic in disagreement. I don't think they do us any favours - particularly beginners who get persuaded to buy unnecessary expensive kit (wheel gauge) and indulge in difficult and often pointless procedures (polishing and flattening).
Mike - Parnham house folded, Barnsley et al is a quirky English backwater. There are many other influences worth taking note of.
I think the "double" bevel is so insignificant that flattening it is not worth the bother. Also it'd make it wrong if you marked up from the other side for any reason. With a normal pin it's the middle of the line which counts either way.J_SAMa":1ki8gipu said:Wheel gauges are fine for marking out joints but are beveled on the wrong side for dimensioning stock by hand. I use a pin gauge sharpened with only one bevel on the side away from the stock.
But I suppose just about everyone dimensions stock by machine nowadays so...
