Compound cut candle holder
_HsMichael
20 Jan 2014
England
Here's a couple of photos of a freshly-cut candle holder I made yesterday. It only took four internal cuts to make and is a project that can be done in an hour or so depending on the wood that you use. In this case I used yew, which was not particularly easy to cut to be honest, next time I will be sure to use softer woods.
Below is a link to a video that I made explaining how I made the candle holder from start to finish:
https://www.youtube.com/watch?v=DbFr1bPHnIg
Here is a link to the original free pattern: http://www.scrollsawer.com/patterns/compound-cut-candleholders.html
I do not intend on keeping the candle shown in the images on top of the candle holder, as it would obviously be a fire hazard. I will either place a tealight in a metal case on top or use an electronic candle. Once cut on the scroll saw, the candle holder only requires a little filing or sanding.
    126.1 KB
    129.7 KB
