Derek Cohen (Perth Oz)
Matt wrote:
Matt, the simple answer may be to just increase the bevel angle of your Marples chisels. Cheap fix!
A chisel whose edge will last forever, eh? Well I'm sure you could get something made in M2 steel, but you will have a lot of fun sharpening them
Everything is a compromise. A hard steel holds an edge but is tough to hone. A moderate steel hold an edge for a moderate/reasonable period of time but is easier to hone.
Like MikeW, I keep a set of Stanley 60's for rough work (actually, they were the first chisels I bought). Alternately, I have several vintage framing chisels (Mathiesons, Ibbotsons, amongst others). Of the vintage chisels I own, the Witherbys have the toughest steel, but I do not think that you would want these for a building site!
Alf wrote:
I agree with the above.
I keep a set of paring chisels (Bergs) with 20 degree bevels. These cut through timber with hand pressure owing to the low bevel angle, but are better suited to softwoods since the edge is more fragile at this angle.
My bench chisels (the Witherbys) are bevelled at 25 degrees. I can push or tap (not hit) these with a wooden mallet.
The Japanese bench chisels and dovetail chisels are reserved for hardwood. All are bevelled at 30 degrees and are designed to be hit with a metal hammer.
I did note that Craftman Studio are selling a "special" set of Two Cherries chisels at a discount price. These are not polished and, therefore, cheaper. Funny that - the polished versions have to be flattened because the polishing process rounds the backs. I would pay extra to get the unpolished version, and here they are selling them cheaper!
http://www.craftsmanstudio.com/html_p/L!5001501.htm
But I would try the Marples with a 30-35 degree bevel first.
Regards from Perth
Derek
... the marples chiselsi currently use are useless, to the extent where the edge has gone dull within a few light hits with the hammer ... i really want a set of chisels who's edges will last well, and also ones that come fairly flat. the marples took what seems like forever to get flat.
alot of the time the chisels will be used with a hammer, so the handles will need to be upto that.
Alf wrote:
I've always believed the rule of thumb was:
Handles with metal hoops - hit 'em wiv' an 'ammer if you like
Bench chisels/firmers/butt etc - mallet, round or square as preferred
Paring chisels - thou shalt not hit them on pain of pain
Plastic handled site chisels - do what you jolly well like 'cos nothing's gonna make 'em worse.
Regards from Perth
Derek
