most of the chisels I buy are well used. if I can find 100 year old ones, more the better. some (most) of these need considerable work to get the flat side flat. not being one to spend unnecessary time rubbing chisels against rocks, I have found some fast and effective if unconventional methods of arriving at a working chisel. the usual problem is that the flat has been rendered convex by years of wiping off the wire edge, using the chisel as a scraper on concrete or such, and similar abuse. generally I will start at the bench grinder, shortening the chisel by just enough to remove the worst of the damage at the edge and establish a new rough bevel. then I will address the flat. if it is within range of flattening on a coarse stone, I'll proceed from there. if it needs more than that, I'll use a pneumatic angle grinder with an approximately 2" disk mounted to carefully hollow out a slight concavity in the center of the flat. from there I will take it to the coarse stone. not wanting to over aggressively remove metal from a nice chisel, I generally alternate a few strokes on the stone to show up the high spots with a few strokes with the disc to remove those high spots (avoiding the edges, of course). when the surface produced by the stone reaches the edge, I'm done with the grinder and can move on up through the grits. this often leaves a few hollow ground areas somewhere on the flat of the chisel, just not right at the edge. over time and honings those do diminish and even disappear. I do generally give the whole flat of a chisel a few strokes on the stone each time I sharpen it- it's just part of the routine.
none of this is specifically about prepping new chisels, of course.
