mailee
I made a start on two new cabinets today and it's a new one for me as they are in Cherry. :shock: Again I used the Domino as the carcasses are in veneered board. Started the day by cutting out the pieces for each of the cabinets.
I then cut the rebate at the rear which will house the back panel. This will be in 18mm as it will be hung from a wall.
Next I attacked it with the Domino putting in the slots for the horizontal pieces.
There will be a small mirrored cabinet with glass shelves and this was given the same treatment with the addition of holes for the adjustable shelves.
With all the pieces cut I had a dry fit using some sanded Dominos to make sure I could remove them again.
There will be a painted door on the bottom of this unit so I cut some MDF to size for this.
Tomorrow I shall be lipping the edges of the panels with solid wood and adding the cornice and plinth. When this is complete I shall put a finish on the insides before assembling the unit. I will as usual keep you posted.
