Jacob
What goes around comes around.
I've had a good look. It's crap. Machining inaccuracies all over which make it impossible to use without a lot of reworking first:-
The frog sits off centre, this sets everything else off of course.
Frog screws are very flimsy and wouldn't last long.
Frog adjuster doesn't quite engage - it gets in the way, better to remove it altogether.
Blade looks OK.
Cap iron is machined off centre by about 2mm.
Lever cap is too short and misshapen.
Blade slot is too wide for the cap iron screw - it'll only just engage if exactly dead central but the hole is off centre anyway!
These features are enough to make it unusable. Didn't bother with checking for flat/square/hard etc.
Pity really cos all the bits look good enough it's just so badly machined in too many places. Some of the machining looks fine - the frog face and back of mouth are perfect, but the frog is offset sideways.
Sod this it's going back, I'm not a metal worker!
Blade looks OK.
