Jacob
What goes around comes around.
I can hear the armchairs creaking! :lol:
iNewbie":3idrwa5m said:Corneel":3idrwa5m said:Conclusion: The Stanley is quite a bit harder.
To give this experiment more substance, everybody should now rush out to their shop and do similar on their old planes, LV's, LN's, QS's, Faithfulls, whatever, and report back. I can't compare with other new planes because I am now pretty sure I don't have any more.
Only one conclusion? I could also conclude the Quengsheng you have maybe softer than another one. Just an armchair theory, though... :wink:
No you could not.iNewbie":2toliqse said:Corneel":2toliqse said:Conclusion: The Stanley is quite a bit harder.
Only one conclusion? I could also conclude the Quengsheng you have maybe softer than another one. .....
But it would contradict the only bit of evidence so it would not be "by reasoning" as reasoning would tell you the opposite. You could hold the opinion but in the absence of evidence this would be just stupid.iNewbie":vnu6y223 said:On no I can conclude: arrive at a judgment or opinion by reasoning
Yes it is.iNewbie":19r0u91y said:Is that so.
A voice from the armchair!woodbrains":3jx9afmj said:Hello,
The QS block plane is made from cast steel, so has little to do with the cast iron that has been discussed; not hardened steel and obviously less carbon content than iron.
Scratch testing on hidden nails..... By the logic that plane bodies hardens varies from plane to plane, could the same thing be said about nail harness? Therefore this test would be even less valid and even more ludicrous than it sounds. For pity's sake, all plane bodies are more than hard enough to do the job they are required to do. Even bronze ones are harder than required. Conclusion: this debate is insane.
Mike
Never a truer word...woodbrains":wvg6gqe8 said:Conclusion: this debate is insane.
It's not only the environment (lot of building going on around me here) - you find bits of metal in virgin new wood, usually (but not always) harmless lead shot. Also if you do repair and restoration, or recycle old wood, the scratch possibilities go up and up.Corneel":cxzzc8zd said:Of course it makes a difference! For example when you are working in an environment like Jacob's. It's a tiny little detail, and for most of us not very important. Just something to keep in the back of your head. .....
