• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Sold Charnwood W850 Lathe For Sale £275 ono
Duncan A
UKW Supporter
8 Nov 2007
Northants
I’m selling this lathe on behalf of the family of a past member of our woodturning club, with proceeds to be split between our club and the local hospice.
It has been well used, with a good deal of dried finishes on the paintwork, but it works as it should and has been fitted with new bearings and a new drive belt.
Distance between centres​
1060mm​
Max diameter over bed​
400mm​
Max diameter over outrigger​
810mm​
Motor (Induction)​
1100W, 240V​
Speed ranges​
2(200 – 1600rpm, 200 – 3200rpm)​
Spindle thread size​
M33 x 3.5​
Spindle tapers​
2MT​
Headstock hollow centre diameter​
15mm​
Tailstock hollow centre diameter​
10mm​
Toolrest width​
355mm​
Faceplate diameter​
152mm​
Headstock rotation​
360 (pre sets at 45, 90, 135, 180, 270)​
Spindle centre to floor​
1130mm​
Dimensions (WxDxH)​
1790mm x 440mm x 1170mm​
Weight​
180kg​
Rating​
Trade​
Sliding and rotating headstock.
Headstock, toolrest and tailstock all have cam-locking levers for adjustment.
A 3ph inverter controls speed and ensures the same power output even at low speeds.
A (TEMPERAMENTAL) digital display gives speed reading on both low and high speed ranges.
Reverse direction selector, 36 position indexing, hollow headstock and tailstock for long hole boring and a handle for manual rotation of the spindle.
Floorstand with four adjustable rubber feet and brackets for a storage shelf.
With four pronged drive centre, revolving tail centre, push button spindle lock, centre knock out bar, floorstand, 355mm toolrest, bowl-turning toolrest, 150mm diameter faceplate, screw chuck, and an outrigger attachment for bowl turning up to 810mm (32″) diameter.
Fitted with new bearings and belts - receipts can be seen.
I'm looking for £275 o.n.o.
If you want to see the lathe (Northampton - easy access), let me know by PM and we'll sort out time and date.
Duncan
    56.4 KB
    98 KB
    111.5 KB
    43.1 KB
