I have a 52Ah 12V Lithium Iron Phosphate (LiFePO4) battery. I charge it with a mains charger that has a LiFePO4 mode. The battery and charger are both new. When fully charged the battery is 14.1V. In use the battery has a load but no charge mechanism. Typically the voltage drops to 10-point-something volts in a single use, and then I charge it again. I have 2 questions:
1. How low can I allow the voltage to drop?
I would like to use the battery for twice as long as I have done so far. Is that possible? Safe? Bad for the battery?
2. Suitability of my charger.
It takes a long time to charge the battery. Reading the "manual" that came with the charger, it says it can charge batteries up to 20Ah and maintain the charge on any battery. 20Ah is less than half the capacity of my battery.
Is this battery & charger combination safe? I have read of fires supposedly caused by using the wrong charger to charge electric bikes. Obviously something I would like to avoid.
If it is safe, will this slow charging harm the battery?
