But plastic pushfit ! Why does the guy have a pipe bender ?I have had the entire heating system ripped out and it’s all brand new.
Not always a good thing, I recently went to a leak where the home owner had fetched the part of the downstairs ceiling down where he thought the leak was from as upstairs it had wooden flooring. It turned out the leak had traveled along the insulation & was infact emanating from a fitting accessible from the airing cupboard.Mine were all insulated as I remember the plumber telling his apprentice to fit the insulation with the slit uppermost so if there were any leaks it wouldn't drip down onto the ceiling, not sure if that was a good or bad thing![]()
I believe heat loss from copper is greater than from plastic. One of the first jobs I used plastic pipework on was a large secondary circulating hot water system, plastic was stipulated by the company supplying the components to minimise heat loss where the pipework couldn’t be insulated.and is the heat loss from PEX the same as copper?
Ian
Moving rad, moving electrics, door stops…..the later caused me to have a lovely unexpected shower once when I hit a pipeHow often did you used to drill into your floors?![]()
The heat loss is greater from copper, UFH pipes aren't 15mm and don't run at 60c from an air source pump so those comparisons are pointless. I can see a reason for insulating pipework if you wish to keep a cold room between the heat source and the heated room, but how common would that be?I believe heat loss from copper is greater than from plastic. One of the first jobs I used plastic pipework on was a large secondary circulating hot water system, plastic was stipulated by the company supplying the components to minimise heat loss where the pipework couldn’t be insulated.
I would guess, that in a world of higher heating costs and wireless radiator valves, increasingly common.The heat loss is greater from copper, UFH pipes aren't 15mm and don't run at 60c from an air source pump so those comparisons are pointless. I can see a reason for insulating pipework if you wish to keep a cold room between the heat source and the heated room, but how common would that be?
A totally unheated room? Unlikely, I'd think.I would guess, that in a world of higher heating costs and wireless radiator valves, increasingly common.
Well we don't heat our barn of a living room in the daytime, as we tend to live in the kitchen, but we do have the heating come on in our bedroom, morning and evening, and the pipes run through the living room.A totally unheated room? Unlikely, I'd think.
Hmmm, plumbers up to their usual tricks. Pipe work looks neat, but how are you going to fix the boards back down?I have had the entire heating system ripped out and it’s all brand new. View attachment 162006
Looks neat except that there are a bunch of unconnected pipes.... My guess is that it's not finished yet. Maybe pipes have been measured, cut and laid in approximate position.Hmmm, plumbers up to their usual tricks. Pipe work looks neat, but how are you going to fix the boards back down?
Most of the elbows only have one pipe connected so I guess that's where the unconnected pipes go. I have the same doubts about fixing the flooring back down. Maybe take up a couple more floorboards and put a large sheet of MDF flooring over the whole lot.Looks neat except that there are a bunch of unconnected pipes.... My guess is that it's not finished yet. Maybe pipes have been measured, cut and laid in approximate position.
Yebbut....a lot of us do not have gas.Of course. Incandescent lamps warm the house in summer and in winter, and by my reckoning, at approximately 3 times the cost of gas heating.
Or Summer?Yebbut....a lot of us do not have gas.
