dvddvd
I wanted to cut some thin pieces/ veneers from some hardwood.
The pieces of timber I have are 150mm high.
I've watched a lot of videos on YouTube and followers there tips.
I bought a Record sabre 450, their biggest model.
I bought a new blade from tuffsaws that the recommended for veneer cutting.
I also bought the Bow bandsaw feather board which is made for cutting veneers.
I set the blade up, it's at maximum tension. I squared the fence and table and set all the blade guides.
I followed all the guides on YouTube and did what they recommended but it still won't cut a perfect veneer.
Sometimes you think you have nailed it and the top looks fine and then realise that the bottom is 2 mm thicker etc.
I don't know what else I can do?
I can get an ok one on a piece of material which is 50mm high, but any higher and its bad news.
As I said the blade is new and it feels fine but it is tensioned to the max, could the blade be a little to long?
