I have a problem that I can’t think of a simple solution for. The plaster for the lounge ceiling in an area has come away from the latte backing and is loose. Never come across it before where the ceiling has remained completely intact and come away from the lattes. Investigating, the plaster wasn’t properly pushed through the lattes in the area when it was done.....circa 100+ years ago! It’s a big room and I’d like to try and keep the ceiling as it has intricate plaster mouldings etc.
I’m thinking that there must be a way of ‘gluing’ the plaster back to the lattes? I can push it back up to the lattes so propping it up would work if I can then fix it. I can’t think of a suitable glue that would be runny enough to fill the voids, have enough open time and sticks to both plaster and wood.
Here’s my initial thoughts
Runny plaster pored between the lattes?
Watered down PVA glue initially pored and then perhaps plaster on top? Glue may puddle??
NO more nails or similar beaded down the lattes
Resin - concerned I might get too much in an area and set fire to the lattes...wouldn’t be a good day!
Screwing the plaster to the joists.....old plaster will probably just crumble and pullback.
Anyone done anything like this before or got any suggestions?
