Cat shelves 🥴🥴🥴
Stigmorgan
18 Aug 2019
Ash Vale, Aldershot
So I've posted a couple of WIP pics on the thing you made thread but I'm a little uncertain about how to mount the bridge on the wall at the minute, it's a bit heavier than I thought it would be and worry about the bridge itself pulling on the shelves at each end, would love some suggestions for mounting them here's a pic of the bridge and the bits of wood I have
Looks grand but I’m struggling to visualise it in its final position- it’s prob just me and the loss of £700 to replace my clutch . Is it going between 2 fixed walls ? or have I missed something 🤔
Ahh I see now - I can understand your concern as you don’t have a lot of surface contact to utilise. So maybe some sort of back panel built into design so you could simply fix it to the wall using plugs and screws etc - my only other thought would be a floating shelf type bracket that could be fixed to the wall and the bridge ends simply slide onto the rails ( if you follow)
That's my initial thought, I'm just not sure on best fixings, I think a red rawl plug might be too small for the amount of pulling force over time combined with the added pressures from the cat using it. I have brown plugs but sure they are enough either.
I scoffed at the price of Fischer duo plugs but they are far superior to the brown / red plugs respectively. 6mm for smaller jobs 8 mm for heavier duty and 10 mm for even stronger . As usual as long as the wall in question is sound and I assume ( solid ) then the 8 mm should be adequate but 10mm if you prefer bullet proof . Cavity walls are never going to be easy unless you find the studs and work to those .. edit I find it best to sink the plug into the brick rather than leaving it flush with the plaster
ischer Duopower Wall Plugs 8mm x 40mm 100 Pack (1820P)
£7.99
https://www.googleadservices.com/pa...s7zd26iLAxU3VkEAHbGJAjkQzzkoAHoECAUQDA&adurl=
Screwfix.com
(4k+)
I don't get why they don't just have any black brackets underneath the shelves?
Is this for your own cats or a customers?
It's for one of the families that SWMBO does P.A work for, the daughter (high level autistic) won't leave the cat alone so I was "volunteererd" to make somewhere out of reach for the cat to escape to, I reluctantly agreed and as usual went over the top and this is what I've got so far, only plan to do 1 more shelf and a rope bound post. The bed, shelf and post will be easy as the wheight is pretty much all vertical but with the bridge it's vertical with a horizontal pull from the bridge slats if that makes sense
@SammyQ I'm told solid, I've not been there myself yet but I'm aware it makes a huge difference 🥴
Unless they've got something like a Maine Coon most adult cats are around 5-5.5kg, so it's not a huge load. If I was doing that I'd use something like this, 2 per side but flipped so the fixings are less obvious
https://www.amazon.co.uk/Floating-B...gid=pla-2281435176938&psc=1&gad_source=1&th=1
It's tempting to say use floating shelf brackets, but if the daughter pulls on the shelf trying to get to the cat...🙀
