Cat shelves 🥴🥴🥴
Stigmorgan
18 Aug 2019
Ash Vale, Aldershot
So I've posted a couple of WIP pics on the thing you made thread but I'm a little uncertain about how to mount the bridge on the wall at the minute, it's a bit heavier than I thought it would be and worry about the bridge itself pulling on the shelves at each end, would love some suggestions for mounting them here's a pic of the bridge and the bits of wood I have
Looks grand but I’m struggling to visualise it in its final position- it’s prob just me and the loss of £700 to replace my clutch . Is it going between 2 fixed walls ? or have I missed something 🤔
Ahh I see now - I can understand your concern as you don’t have a lot of surface contact to utilise. So maybe some sort of back panel built into design so you could simply fix it to the wall using plugs and screws etc - my only other thought would be a floating shelf type bracket that could be fixed to the wall and the bridge ends simply slide onto the rails ( if you follow)
That's my initial thought, I'm just not sure on best fixings, I think a red rawl plug might be too small for the amount of pulling force over time combined with the added pressures from the cat using it. I have brown plugs but sure they are enough either.
I scoffed at the price of Fischer duo plugs but they are far superior to the brown / red plugs respectively. 6mm for smaller jobs 8 mm for heavier duty and 10 mm for even stronger . As usual as long as the wall in question is sound and I assume ( solid ) then the 8 mm should be adequate but 10mm if you prefer bullet proof . Cavity walls are never going to be easy unless you find the studs and work to those .. edit I find it best to sink the plug into the brick rather than leaving it flush with the plaster
ischer Duopower Wall Plugs 8mm x 40mm 100 Pack (1820P)
£7.99
https://www.googleadservices.com/pa...s7zd26iLAxU3VkEAHbGJAjkQzzkoAHoECAUQDA&adurl=
Screwfix.com
(4k+)
