You might try Cromartie Timber, Strathpeffer. They are knowledgable .... & reasonably priced. They also take the time to cut out curvaceous or difficult timber to best advantage.
Carriers are not that expensive ........ unless you live on one of the Scottish islands .... £28 to deliver a couple of tubes of wood glue......... but with regard to wood, getting a few big lumps of mahogany from Bristol was not that expensive.A 1300+ mile round trip might be a bit of drive.
I think it's the same but it's warmer here which makes the difference. Ours sucker as well.It's probably a different elm - ours doesn't (usually, afaik) spread by seed but by suckering.
Thanks Phil.You have a lot of cultivars, possibly more than we have -
https://en.wikipedia.org/wiki/Elms_in_Australia
Yes our 300 year old cottage has elm beams and wide elm floorboards in one room, some of which have been replaced with modern boards over the years and just carpeted over so my plan is to source replacement elm floorboards next year.One reason Elm is pricy is you can get really wide boards. Before Dutch elm it was a common material for seats and floorboards in place of oak. Our old house had floorboard 14 to 18 inches wide some even 24inches, it was cheaper than oak but susceptible to woodworm.
Like the poem. We had an old thatch cottage dating from 1430 and it had elm beams in one room that were 14 inch square section in a cross with joint in the centre of the room, however the tong joining the cross piece was only 2 inches thick!. We decided to put a post under the joint. They were all wormy on the outside, but not in the centre the worm only ate the wetter bits.I had a house which I believe was built as three one up, one downs. Two lintels crossed in one corner, one pitch pine and one of which there was just enough left to identify it as elm. The pitch pine was as the day it was put there, the elm I took out in handfuls.
Incidentally, the oldest known poem in English is supposedly
Elum hateth man
and waiteth.
it can be be treacherous stuff to work on and fell.
The interesting thing is that as far as I know underwater it was really rot resistant and is why it was used for lock gates.The pitch pine was as the day it was put there, the elm I took out in handfuls.
That's because it's at the northern end of its natural range here - the Romans are supposed to have brought it over here (possibly to use in vineyards). One of the reasons we had Dutch elm disease so badly is that there is/was so little genetic diversity amongst our population of elm trees, because - as you mention - they're produced by vegetative not sexual reproduction in our climate.It's probably a different elm - ours doesn't (usually, afaik) spread by seed but by suckering.
