G S Haydon
- Joined
- 24 Apr 2013
- Messages
- 1,667
- Reaction score
- 223
I have a wooden Jack 47.5 (I think). It's not so old, I can grab a couple of pictures tomorrow if interested.
Cheshirechappie":1yq6806y said:AndyT":1yq6806y said:But why "York pitch"?
Certainly, York was an important centre of plane making, but as far as I am aware, York plane makers made any pitch angle their customers wanted. Peter Young confirms this but offers no suggestion that York Pitch started in York.
It's probably an unanswerable question.
Same reason that a full-pitched delivery in cricket is called a 'Yorker' .................. OK, maybe not!
I'm not lucky enough to own one, but I'm sure I've read that Norris smoothers are all 47.5 degrees.swagman":9g1rer6n said:Although a 45 degree bed is referred to as Common Pitch, 47.5 does seem to have been the more popular choice in the U.K for double iron wooden bodied bench planes.
Its likely that 47.5 was considered much more effective at working a wider range of timbers that included hardwoods.
..and indeed 47.5 is referred to as "Norris Pitch" here : http://sauerandsteiner.blogspot.co.uk/2014/11/the-we-can-do-this-plane.htmlVann":34rxgg65 said:I'm not lucky enough to own one, but I'm sure I've read that Norris smoothers are all 47.5 degrees.
i think this is a very good point Woody - 13 in 12 gives an angle of about 45.5 - I looked (in vain) to see if there was some wierd Roofing terminology that might have been handed down to the plane makers, but it seems notWoody2Shoes":3pvh9kr4 said:I think it's worth bearing in mind that the old boys almost certainly didn't think/work in degrees (and they didn't think/work in metric for similar reasons!) - they thought in terms of ratios. I reckon that a ratio of 10 to 11 would give a pitch angle of about 47.7 degrees. My 120-plus-year-old roof is pitched at a ratio of 11 to 10 (42 point something degrees) and I've never measured the rise and the going of my staircase. Cheers, W2S
G S Haydon":2mt4u3gs said:Not had time to head into the garage but it seems like Andy has similar stats to what I had.
For a left field look http://pinie.cz/en/wooden-planes, I have a few but not had a moment to use. The pictorial instruction on the backs of the packing boxes they come in are quite concise and instructive. Smoothing plane bedded at 49 with a double iron http://pinie.cz/en/our-products/smoothing-plane.
They are very "workmanlike", however I'd like to take my Pinie try plane for a spin and see how it performs.
