Obviously you're a newcomer to the bandsaw market.
Bigger machines can be bought for very little.
This machine cost me 500 quid (euros)
There's a Socomec 560 saw going for under 500 quid on the bay, (buy it now)
and another the same for loadsa cash.
Not quite as nice as some Italian machines though.
i.e cork/rubbertires I've seen on some,
smaller motor possibly, undersized really if only a 2HP/1.5KW motor .
Guide post looks like withoit rack and pinnion
(all features which are likely better on the Eastern machines)
I run this 3 phase machine via a hundred quid VFD and it works just fine from the 13a household plug.
It's got a three horse 2.2kw motor (
dual voltage motor, which can be run on
240v)
(adjustable
startup to suit supply, as that's where the problem lies with single phase, runs on something like 4 amps stationary.
Around the same as me auld laptop.
Say you want to get all the options, once again Bob's induction motor document goes step by step through all these options.
Massive 24" Italian machine compared to a compact far Eastern 20"
Seems an Italian 20" machine will be too large,
but a Far Eastern won't be any larger,
and could be got for a steal if open minded to the three phase market.
i.e 500 quid, double that for the nicer Centauro 500, or nice SNAC 540 machine.
Very compact machine, and equal or lesser footprint to something on legs
like this one for example.
The 20" is a lot easier to move also.
No reason not to look for a 3 phase bandsaw IMO,
so much smoother compared to the startup of single phase,
say for even a wee cut, it might make the difference between choosing by hand or machine, I wouldn't be as keen to use otherwise.
But there is other factors also which makes a more spacious machine more user friendly like larger table which I wouldn't be without now. less dust and safer.
That doesn't sound like an option for you,
but nothing stopping one from making some hinged table if wanted.
Hopefully you can get an impression of both in the shed.
A grand would likely get you a very nice machine if you wait
and study Bob's document.
You might even find it interesting!
Some machines below for insight.
Waste of space, compared to something capable
A 20" lemon i had which got returned...
Shoulda tested it before making a base up for it, lol.
How bout some more machines from the bay
I have a nice collection of piccies grabbed from the net
A happy chappie with what looks to be a 20" machine.
Just to give an impression of size difference between a budget machine and a premium Italian one
Or how about a nice Wadkin, once again larger footprint
T'was 800 pound good few years back
You might have spotted this one from a dealer, that's a 500 quid upcharge.
was sitting for a good while
there was a larger one listed at the same time, in similar nick for cheaper
This SNAC was going for nearly 2 grand, or best offer... it was listed for about a year.
Iwonder what they took for it?
It may have been serviced to be looking for that much
I could try and find an real old Startrite 502,they look pretty good too.
These last few are just some of the other premium machines,
bout 20 different Italain machines which might be an option if too cheap to resist,especially if its a Centauro
These will generally command the highest prices as they can do it all in the littlest space.
The Eastern equivalents (in wheel size) on the bay will be half the price
but do make sure it's running well, as you could be lumped with a lemon.
Some are larger than others.
(all Italians share most of the same components, Euro guides tool free , pricey stuff like guides from Scott and Sargeant, but bearings and belts are standard, cheap and available everywhere.
Good luck with whatever you choose
All the best
Tom
p.s Hopefully you might get the impression that you will get all the advise
you need in step by step easy digestable fashion,
should you wish to go the three phase VFD route.
There's about 20 things to learn which wouldn't take long to go through.
There's never disagreements in regards to parameters, everyone will advise the same thing.
Just sayin incase you find a nice machine going for real cheap,
its good to know what to look for.
I can post a few other dual voltage motors later if I can find some examples
like whats on Bob's document.
See 220-240v (volts) that's yer household supply
The D is for delta...low voltage configuration, takes about 1 minute to take off terminal box lid and and change three straps around, possibly already done for you, possibly schematics to show you, or here or "the other place 2"if stuck, say if you like it from the horses mouth.
Delta is often noted by a triangle symbol most of the time.
You just gotta see
240v on a three phase motor nameplate, and you've got something which will run with a VFD/inverter.
I wouldn't go beyond 3hp/2.2kw if using a 13a household plug.
You can de-rate the motor, but I cannot advise about that as I only know the basics and like to play it safe.
Three rules
No touchy input and output wires,even after unplugged caps inside store lethal charge.
No pluggy in between motor and VFD
Understanding the parameters is vital, as some of these are set at factory default 400hz (RPM related) which would cook the motor going so fast.
Takes about 2 days to be familiar with everything.
Ask away if unsure about these parameters,
Likely will get more answers with a premium unit ,
and any answers you will get here or the other place2, will state the same thing.
Tom
