Boxford Union PD8 Overhaul/Re-build/Restoration
9 May 2024
Colchester
Bought a nice example, but it was noisy as hell, so knew it needed bearings all round. And it hadn’t been greased since the 80s judging the smell and colour of the grease.
Most of the disassembly was simple, two things tripped me up, removing the high low gear (the shaft that resides in the oilite bearings and has the large funny material gear), and the top spindle gear.
Couldn’t find a thread on a forum that explained these foibles, so maybe this will help someone?
1st pic is off the saw dust accumulated in the switch housing, yuk. Also the divider(?) plate.
2nd pic is the machine, stripped partially.
3rd pic is the grease removed from the gear area, accessed from the top, under the plate,
4th pic is the high low gear shaft, there’s two grub screws, and at the bottom is two ball bearings that retain the gear shaft to the carrier shaft.
5th pic is what really stumped me, as the spindle dropped out, and left the upper drive gear in place. Basically, it’s a circlip that holds it, well covered in 50 odd year old grease. I used the outside of a small pair of flat jawed pliers to get it off, as circlip pliers are near useless (I considered trimming the handles of a large set). Once this is done, it’s plain sailing.
6th pic is all the internals, cleaned and inspected.
Next is the motor, 400v, 3 phase, 0.5hp affair. I’ll hopefully get some better pics of that. Wondering if it can be re-wired to 240v, 3 phase, as I don’t want to buy a motor, just a VFD. There’ll be a posts of a few other things as well.
Any questions, I’ll try and answer them! I’ll have some of my own for sure.
All back together now, and spins lovely. It was so much easier putting it back together.
The gear selector handle was missing when I bought it, so I’ve bought another handle. It was missing because the 3/8BSW threads had been mullered in, so it’s been V-Coiled in the original size.
The motor is a single voltage affair, so I’ve got hold of a dual voltage one. Threw some new SKF bearings in it, cleaned the years of crud out of it and wired it for 240v 3 phase. Awaiting anti tracking paint as the interior motor body has some missing.
Next step is VFD purchase, switches and wiring. Wiring is the problem, as I believe twin core and Earth 1.6mm wire will be fine from plug to VFD, then 1.6mm 3 core and Earth from VFD to Motor. As I’m installing a on off switch between VFD and motor, what size will that need to be?
I’ve been specked a 2.4amps VFD, but the name suggests it is better suited for a 0.40kw motor. Been assured it’s amps that is used, not KW, what’s the consensus here?
The motor draws 2.4 amps max and is 0.55kw (0.75hp).
I bought the top spindle bearings new old stock, these go in the head of the drill, under the spindle pulley, there’s two.
This is for the spindle nose, there wasn’t a premium brand, so got generic.
This is at the top of the spindle, may not be totally correct, but fit well and available.
This also at the top of the spindle. Must of thrown the box out.
They are readily available, but the prices jump quick from generic to premium, and the premium are normally on back order, the NSK one had to come from manufacturer. I sourced mine from a certain well known auction site, and two from two different bearing suppliers.
Boxford sent me the parts diagram, that kind of helped as it’s for the Mark 2 PD4, but had bearing names and sizes required.
Not needed parts as such, but I doubt they are readily available.
As for the VFD, I’m looking at the IMO SD1 range.
Hope this helps. Any questions, I’ll try and help.
No problem. It’s quite a simple machine to disassemble, there was three points that really got me, but got them worked out. There was so much grease it was hard to see what was what.
I got another motor, as buying a 240V single to 440v three VFD is pricey, too pricey for me. This is just a project, not a business, I have little use for it really, but there is times I could do with one.
Hi great post I've just bought a mk2 pd8 and am currently in the process of stripping it down, I have emailed boxford for a parts diagram however they have yet to respond, but after reading your post I'm a little more confident if they are unable to supply me with any info
They are good drills, not had any problems with it since the rebuild, drills as true as I need. Trying to mount the VFD controls at the moment.
Not really sure of the Marks, not really delved in to it that far. Does it have the safety bar on the base?
i have one of these drills what use is a VFD ,could you please explain
Mine came with a 3 phase motor, and didn’t want to change it, so got a VFD for it. It controls the speed, how it starts and stops, and direction of the drill, and creates a false 3 phase by converting 1 phase. You can do the same for 1 phase motors, so you can control them in the same way.
I bought the top spindle bearings new old stock, these go in the head of the drill, under the spindle pulley, there’s two.View attachment 182833
Hi. Many thanks for the article on the Boxford/Union PD8 rebuild. I am doing the same at the moment, having picked up a shabby one on that auction site.
Could you help me with a couple of area's that are baffling me please? Like you said, I have scooped out wads of old grease from both the top section, and the bottom of the 'head'.
But. The machine I have only has one grease nipple, on the underside of the bottom of the 'head'.
So how does grease get into the top part of the head please?? Is there a grease nipple missing on my machine? Or is the gear area and the main top bearings greased by hand on assembly?
Secondly, you mention the 2 grub screws in the top of the gear change gear ( with the big unusual material gear), but having taken the 2 grub screws out, how do you get the shaft out? Mine seems stuck solid? Does it come out the top? How does it slide free from the gear below?
I'm probably missing something stupid, but don't want to force anything.
I would be very grateful for your help please.
Regards. Martin.
Regards. Martin.
After removing the two grub screws, there are two ball bearings in the shaft, reached from the top of the machine, you’ll need a suitable magnet to get them out. The second grub screw pushes these two ball bearings out in to the recesses, the first removed grub screw is a locking device I assume.
To removes the second one is a circlip, there’s a photo of it in my original post, very awkward to get to, and the grease camouflages it.
I just hand greased the gearbox on assembly, no grease nipples for it.
There are two grease nipples on mine, one on the underside towards the back and one on the handle, think these are more for oil than grease though, as oil is also required to lubricate.
Hope this helps.
Hope this helps.
It most certainly does help. Thank you so much. I hadn't considered getting the ball bearings out with a magnet. I'll have a go in the morning.
I did notice the hole in the centre of the handle, and today also noticed that there is an 'exit' hole a little way along the shaft. Mine doesn't have a grease nipple in it, but I will now fit one.
Very very grateful for the help. Regards. Ewbin.
Once you get the spindle out, there is a nut at the top that keeps it all together, it requires a pin spanner to remove. Before that though, there’s a grub screw made of brass in it that needs to be removed.
Dave
