brendan_bjg
I'm partitioning off my garage so part of it can be a work from home area. I can't take the stud to the ceiling due to the garage door & motor. I am going to box it off, and put a door in the stud wall for access between the 2. There is another door in the working area; I'm just making sure I've 2 exits in the room incase of fire. The stud along the wall is the start of boxing off the motor. I've anchored it to the wall with 8mm concrete screws, it will have supporting studs from the ceiling, and obviously studs coming from the stud wall aswell to form the ceiling (so getting support from the stud wall aswell. It will be boarded and plastered, with an access panel to the motor incase of maintenance. Noggins also yet to go in.
Do you think that is enough support for the box round the motor? Should I have used sleeve anchors in the wall, or are concrete screws sufficient?
