dean0866
Boxer,
Have you made any further progress?
Well I took the advice on this thread and made the bench top a lot thicker than the Bosch instructions recommend. I glued and screwed 3x 18mm x 600mm x 1850mm chipboard together and added an 18mm thick piece of MDF as the main top to hide the screws and give a flat surface. It’s certainly heavy and seems quite robust although I haven’t mounted it on the legs yet as I have to cut the tenons and connect the front rails first. I just hope the legs can take the weight!
