I've not had a lot of time in the workshop recently. Anyway, I planed and thicknessed the table tops at a friend's workshop, where he has a huge P/T. Back home, I cut the tops to length using a cross-cut saw, but knowing how vulnerable this wood is to breakout, I pre-scored the underside with a knife:
I spend rather a lot of time cleaning up the cracks with a chisel, and then used a card scraper to clean up the marks left by the planer:
Not being brave enough to start with epoxy etc, I decided to detour onto the drawers, which are going to be of oak (possibly with a sycamore base....we'll see). I needed to re-saw some 25mm stuff to make the sides, so I set up my re-saw fence:
.....and ripped the stock up the middle:
I then fitted the drawer fronts tightly into the holes in the frame:
They're much blacker than that in real life. I think the flash is playing tricks with us.
After planing the drawer sides to the same height as the drawer fronts, I marked out the tails and cut them out:
I seem to have failed to take a photo of the completed tail boards. Ho hum.... Thence to the pin boards (drawer fronts). It's an absolute pain not being able to see any marks on this dark wood, so I used tape:
I've got an old plastic handled knife from a kids cutlery set, cut off square at the end, which I use for driving down into the saw kerf in half-blind dovetails:
Then it's just more careful chiseling:
And a reasonable first joint:
I then diverted again, and mocked up a drawer-pull idea:
My wife's reaction was "it's a bit clompy", and she's right. I'll play with a scaled down version and see if it looks a bit better in a more refined size. If anyone has any wooden handle suggestions, please feel free to drop a photo or link in here.
