I haven't even looked at this for a couple of weeks, so it was great to get a few hours in the workshop yesterday evening and today. I started by rifling through my stash of spalted sycamore, looking for something to use for drawer bottoms. This looked like it would work:
Unfortunately it was very much "in wind":
To save wastage I cut it to length, and halved the width:
Flattening from there only cost a couple of millimetres of thickness. I then proceeded to the bandsaw for re-sawing:
Looks good, hey?
Well, it's all gone on a bonfire. It was riddled with woodworm, and I came across at least 2 live larvae. I chucked probably a quarter of my spalted sycamore on the same fire. So, there's a couple of hours wasted, and I started all over again.
This time, I grabbed some ash:
After re-sawing and planing it was down to about 10mm for the glue up:
I did both drawer bottoms of course, and they were in clamps overnight. This morning, I cleaned them up:
I ran the grooves around the front and two sides of the drawer carcasses which enabled me to accurately measure the size of the drawer bases. I cut the bases to size, and ran a rebate around 3 sides to get them down to the thickness necessary to fit the groove. We're dealing with fairly critical dimensions here as the drawer sides are thinnish.....8 or 9mm, so the grooves aren't deep:
Dry assembly:
The back edge of the drawers bottoms will be screwed to the under-edge of the rearmost member of the drawer carcass, so I did the grooves for those:
I forgot to show the through dovetails for the drawer backs, but they were quick and easy. Here is one of the drawers glued up:
Note the pinch-sticks for checking the diagonals. No need for clamps, as all the jointing is really tight. I glued the front edge of the drawer bottom into the drawer front groove, and then the sides about a third of the way back up the drawer. Any movement there will be minimal. Behind that, it's floating free.
This morning I had also glued up the table top:
Note the plastic scraps to keep the steel of the clamp away from the glue and the oak. Those three can be a nasty combination if they come into contact:
I also prepared a scrap for a test of the resin/ brass mix:
I used a hot melt glue gun to seal up the underside and ends of the cracks, but I wasn't as assiduous as I should have been. Frankly, I had no idea this stuff would have the viscosity of milk. It was surprised by the colour of the brass filings when mixed into the epoxy:
And yeah, it leaked:
I did the epoxy in the house because of the warmer temperature, but apparently it smells a bit so I won't be doing that again.
