SteveW1000":uqc6e67w said:I've also got a Delta don't think that the spindle unscrews its more a case of exchanging the rubber sleeve to a different size. I don't use the smaller sizes much and got Carroll to drill two of their spindle moulder drums to fit, 2" and 3" which allow me to use strips of abrasive paper rather than sleeves. Don't know if they will still do this I had to wait for them to reset the machines at the end of a production run.
Steve
Mike Wingate":2a46epgv said:The fence is made from 4 hpieces of Baltic birch ply. The vertical fence is laminated for thickness and sandwiches the blue t track. Two hand wheel/knobs lock the fence onto the 2 t tracks on the table, they ride in slots to give an angled fence. The two stops on the vertical fence run in the fence t track and do come in useful.
Green":1d3t2v8e said:I even trust it enough to have used it to thickness down the headstock on a finished guitar.
whiskywill":yq71dp96 said:Green":yq71dp96 said:I even trust it enough to have used it to thickness down the headstock on a finished guitar.
I'd be interested to know how you held the guitar to ensure it stayed at the correct angle. Was it before you had cut out the head profile?
I have just finished an Irish Bouzouki and, stupidly, trial fitted the machine heads upside down. So the plan is to thin down the headstock and fit a back veneer to cover the screw holes.
Green":z8cchjfv said:Yep it was pretty much at the finish sanded stage. I had to thin down the back of the head as the front had a thick veneer that I hadn't accounted for.
I just held it upside down against a temporary fence and fed it against the direction of cut. Any up and down movement wouldn't matter until I reached the volute so I just let it ride on the table and made sure it was hard against the fence. The hardest bit was having to do all this on the floor as it is a neck through bass an was bumping against the ceiling of the garage. Measure twice and all that...
