They are all a compromise with good and bad points but by and large I think the Bailey design is utterly brilliant - an inspiration followed by many years of detailed refinement.condeesteso":31et710g said:... whichever way it is looked at the BD Bailey design has issues I think. .....
condeesteso":1mef0gih said:No such thing as a cold thread... ask Sherlock.
Now then - there is a basic design problem with B/D planes is there not?
The frog has one position where it works - just the one. That is when the frog is perfectly aligned to the sole support. Only then do we get true and complete blade support.
Therefore, I could argue that the frog is an irrelevance, or at very best a poor solution to an obvious requirement. I say that because it is designed to move forward and back, but only REALLY works in one single position.
It would be smart to adjust blade thickness to close the mouth, in that case. Or make the mouth adjustable independent of the blade and support assembly.
No shooting here, I've long held this view. Although a method for making it adjustable was something of an afterthought, at least for Stanley - not until the type 10, I think? 1907 or thereabouts? So they didn't truly cotton on to the "advantage" sales point 'til quite late on. And after they'd explored it more fully with the Bedrocks.xy mosian":68x0wef9 said:I'm prepared to be shot down here ... so take aim.
How about a possible plane designers conference topic from the mists of time? "We cannot easily grind the bed of a frog when cast in one piece with the body of the plane. Therefore we'll make it separate. To make it look like an advantage, for selling, let's provide a method of making it adjustable"
Bevel up, I assume? Just clarifying, 'cos this gets confusing enough as it is.Benchwayze":68x0wef9 said:There was a time when the only bevel down planes generally available were the small block planes. very useful of course, but not my ideal choice for 'planing' stock to square.
Agree.Alf":2clkkyo0 said:No shooting here, I've long held this view. Although a method for making it adjustable was something of an afterthought, at least for Stanley - not until the type 10, I think? 1907 or thereabouts? So they didn't truly cotton on to the "advantage" sales point 'til quite late on. And after they'd explored it more fully with the Bedrocks......xy mosian":2clkkyo0 said:I'm prepared to be shot down here ... so take aim.
They didn't catch on. This mouth adjustment thing is a bit of a red herringcondeesteso":1lrb5fxj said:....But finding old Bedrocks seems difficult.
Yes - with just the one plane perhaps a 4. You only need one uber smoother. The others all need to be normal configuration for normal use..... I suspect the best solution with a Bailey is to fit a thicker blade, effectively closing the mouth down, and tune it for fine smoothing only, i.e. a permanent tight mouth. Align frog to sole exactly for support, and if necessary remove as little as possible from the leading edge of mouth to give say 5 thou clearance.
Mike Wingate":3gcfuzx2 said:I planed with the grain, diagonally, reverse, It still tore up, even though it is a very sharp and stiff blade, minimal mouth, good contact with the frog, etc. A poor finish. If only for these occasions and a bit of shooting, I may purchase a Quangsheng LA 62.
custard":13fzkgtt said:Moral of the story...if tearout's the problem then maybe try a scraper plane before resorting to a low angle plane.
bugbear":38tozhrs said:There have been many reports that planing gives a better finish than scraping if (of course) you can plane without tearout.
bugbear":xkz4oc3j said:custard":xkz4oc3j said:Moral of the story...if tearout's the problem then maybe try a scraper plane before resorting to a low angle plane.
BugBear
Jacob":2wvslkcg said:Agree.Alf":2wvslkcg said:No shooting here, I've long held this view. Although a method for making it adjustable was something of an afterthought, at least for Stanley - not until the type 10, I think? 1907 or thereabouts? So they didn't truly cotton on to the "advantage" sales point 'til quite late on. And after they'd explored it more fully with the Bedrocks......xy mosian":2wvslkcg said:I'm prepared to be shot down here ... so take aim.
custard":2m7kyzqb said:bugbear":2m7kyzqb said:There have been many reports that planing gives a better finish than scraping if (of course) you can plane without tearout.
BugBear
When it comes to wild and interlocked grain then that's a mighty big "if"!
