- Joined
- 6 Jun 2011
- Messages
- 2,975
- Reaction score
- 884
After all this BU hype I am keener than ever to give the 62 a good play and test at the” No 62 Bench Plane Battle”
No, honestly! Problems could be due to not having things screwed down tight enough, or bad fit between cap iron and blade - both easy to fix.condeesteso":3jcg1ozo said:.....
Chip-breaker: acknowledged as a likely problem area by anyone being honest about them. ...
Not for me (except the odd occasion when I've tried an impossible cut i.e. forgot to set the blade). Trapped fragments means bad or loose fit.... the throat clogs very easily, fragments trapped between chipbreaker and blade.
BU have no lateral adjustment at all IME (unless you loosen the lever cap first but even then the adjustment is crude with too little leverage) but it's not the end of the world - what else are pin hammers for? But if you do have a good tilt mechanism then it does get used a lot, specially with cambered blades and/or board edge joineryLateral adjustment: BD generally have more lateral adjustment, but enough is enough and BU have enough plus some. If I ever grind a blade so off-square that I need all the adjustment a BD plane offers, then I deserve problems, and will get them with the chipbreaker again. So most of that lateral adjustment on a BD is of no value.
Not worth the bother on a BD, don't even try it! Then you don't miss it either.Mouth adjustment: .....
No snobbery - I'm all for making life easier but these planes all have their strengths and weaknesses. I'm more often accused of reverse snobbery so I can't win either way. LN are at least honest in recognising that a short norris adjuster is pointless (for tilting)Blade setting: it is implied (stated even) that BU are better for beginners, easier to set-up and use. To me this has the whiff of plane snobbery about it. The LNs I refer to above have no mechanical lateral adjustment, you do it by hand and feel. There is an argument that in lateral adjustment, the BD is for the novice, not the other way round.
My BU is definitely worse - the norris adjuster is such a finely engineered good fit that it come out with the blade and I have to fiddle about getting it back in. Perhaps it'll be better when it has worn in a bit.Repeatability: I don't think either wins - there is enough play in the location points for it to be near impossible to remove the blade or blade assembly, and have it go back exactly where it was. Neither is better or worse.
Yebbut frinstance the norris adjuster looks like a more intelligent solution but it doesn't work! Intelligence is more than skin deep.My view is that the BU is a more intelligent design solution
I'd recommend paying a bit more attention to this mouth/chipbreaker problem as it is an easy fix. Same as RichardT's "thrrrrrrrap!" :lol:......
Well set-up BD planes are great... but however hard I try I will not make any of them actually better than a BU equivalent, and they will always be the first to offer up problems, mainly in the mouth / chipbreaker area....
Jacob":1qdtwxcz said:No, honestly! Problems could be due to not having things screwed down tight enough, or bad fit between cap iron and blade - both easy to fix.condeesteso":1qdtwxcz said:.....
Chip-breaker: acknowledged as a likely problem area by anyone being honest about them. ...Not for me (except the odd occasion when I've tried an impossible cut i.e. forgot to set the blade). Trapped fragments means bad or loose fit.... the throat clogs very easily, fragments trapped between chipbreaker and blade.BU have no lateral adjustment at all IME (unless you loosen the lever cap first but even then the adjustment is crude with too little leverage) but it's not the end of the world - what else are pin hammers for? But if you do have a good tilt mechanism then it does get used a lot, specially with cambered blades and/or board edge joineryLateral adjustment: BD generally have more lateral adjustment, but enough is enough and BU have enough plus some. If I ever grind a blade so off-square that I need all the adjustment a BD plane offers, then I deserve problems, and will get them with the chipbreaker again. So most of that lateral adjustment on a BD is of no value.Not worth the bother on a BD, don't even try it! Then you don't miss it either.Mouth adjustment: .....No snobbery - I'm all for making life easier but these planes all have their strengths and weaknesses. I'm more often accused of reverse snobbery so I can't win either way. LN are at least honest in recognising that a short norris adjuster is pointless (for tilting)Blade setting: it is implied (stated even) that BU are better for beginners, easier to set-up and use. To me this has the whiff of plane snobbery about it. The LNs I refer to above have no mechanical lateral adjustment, you do it by hand and feel. There is an argument that in lateral adjustment, the BD is for the novice, not the other way round.My BU is definitely worse - the norris adjuster is such a finely engineered good fit that it come out with the blade and I have to fiddle about getting it back in. Perhaps it'll be better when it has worn in a bit.Repeatability: I don't think either wins - there is enough play in the location points for it to be near impossible to remove the blade or blade assembly, and have it go back exactly where it was. Neither is better or worse.Yebbut frinstance the norris adjuster looks like a more intelligent solution but it doesn't work! Intelligence is more than skin deep.My view is that the BU is a more intelligent design solutionI'd recommend paying a bit more attention to this mouth/chipbreaker problem as it is an easy fix. Same as RichardT's "thrrrrrrrap!" :lol:......
I've got both and sometimes one seems to be working better than the other and vice versa. I think the BU has the edge sometimes but only with very difficult grain where it's touch or go anyway, and scraper or sandpaper is the next step. But the BD has the edge on usability and convenience, once you have cured the "thrrrrrrraps", and hand sharpening is a lot easier
And they are so much cheaper - we live in a post hand-tool era where the market is awash with excellent old hand tools at very low prices.
PS re. cap iron prob above, it might help to back off the blade contact edge of the cap iron a touch, to make it a closed tighter fit at the sharp end so that shavings can't get in. And ditto with the top edge so that shavings will lift over - and polishing helps here. I've had cap irons which were just cut off square at the end so shavings would just jam up against the edge straightaway.
PPS it might also be due to having the frog forwards, the less supported blade can then "thrrrrrrrap" and allow the sharp end of a shaving under the cap iron.
Can be if you get a dud.bugbear":3sxr6pq1 said:....
These BD planes do sound complicated... ;-)
BugBear
Jacob":2f8k475u said:Would the LN 5 1/2 have chipbreaker problems? I wouldn't know.
Oh yes I borrowed Brian's some years ago. :shock:bugbear":3ckk57c9 said:Jacob":3ckk57c9 said:Would the LN 5 1/2 have chipbreaker problems? I wouldn't know.
I wouldn't expect it to behave any differently to the chipbreaker in a LN 4 1/2, which you already know about.
BugBear
Jacob":nl6lcyy2 said:Remind me what I said about it BB, I've completely forgotten. :roll:
What is that weird looking item? Some sort of *** lighter?Richard T":hi829jes said:...
You were wanting a good rebate a while back Jacob. What do you think? (Might be a tad pricey though...AND you wouldn't like the adjuster )
Jacob":1ll1ji2w said:Would the LN 5 1/2 have chipbreaker problems? I wouldn't know.
What you too? Come on pull yourself together!bugbear":3dr2slkf said:Jacob":3dr2slkf said:Remind me what I said about it BB, I've completely forgotten. :roll:
Must be an age thing... :lol: :lol: :lol:
BugBear
Mine don't either, though they are all tatty old bits of bent metal!Peter T":3nafileq said:Jacob":3nafileq said:Would the LN 5 1/2 have chipbreaker problems? I wouldn't know.
Mine doesn't!
It's a fully machined, properly engineered piece of equipment as opposed to a bent piece of sheet metal.
woodbloke":35le70yx said:Perhaps the very best thing about BU planes is that you don't have to consider that hideous, ghastly 2 part chipbreaker that some BD planes seem to sport - Rob... :mrgreen: outa here by the fastest means possible!
:lol: :lol: - RobPaul Chapman":3uamrdax said:woodbloke":3uamrdax said:Perhaps the very best thing about BU planes is that you don't have to consider that hideous, ghastly 2 part chipbreaker that some BD planes seem to sport - Rob... :mrgreen: outa here by the fastest means possible!
I heard that........... :lol:
Cheers :wink:
Paul
