I've extended my shed but the original bit has a sagging roof. Any suggestions the best way to straighten it up and strengthen it? I've thought perhaps some verticals on the wall and new trusses but not sure how successful that might be considering the framing is barely 2x1.
Also considering putting a stronger length of wood alongside that middle sagging bit and fixing them together while they are being pushed up?
It's a 3m x 3m shed (before the extension) and that span is clearly too much in the original design.
p.s. the plasterboard holders are mostly just to show where the problem is. Without them it sags about 2 or 3 inches.
p.p.s. "cheap" sheds are not good
Cheers,
Carl.
Cheers,
Carl.
