dedee
Supposing I could get hold off some short lengths of 5mm diameter stainless steel rod. How easy would it be to bend? Over a distance of about 12" I would only need the apex of the curve to rise about 1".
If I were to cut the curve in the middle of a block of wood & then place the rod between the two pieces and clamp together would that produce a curved rod or a spring?
Would brass bend more easily than stainless steel?
If bending stainless rod is possible (in a simple home workshop) where can I obtain a short length ie about 1m?
Andy
Andy
Andy
Andy
