How thick can I bend a thin brass sheet without annealing the brass? I want the brass sheet to fill a small gap between metal and wood--a slight curve. The gap is 10mm deep.
I recently bought a small sheet of brass 1mm thick thinking that would do the trick. The sheet will bend --with force-- but the job I want it for is a musical instrument so I want a pliable strip of brass to take the curved shape . No problem the get to the 1mm gap using thinner thickness brass to build up to the 10mm I want. Your advice on what thickness to get so it will bend into shape without annealing?
After a bit of research would half-hard brass bend to automatically take the curve?--without annealing? If so what would be the maximum thickness of the brass plate?
