Paddy Roxburgh
Rxh, how do you prep/sharpen the file for scraping?
Student":1kjd05xe said:...is that I noticed that Paul Sellers makes the point that you should keep the blade and cap iron in place when flattening the sole whereas Chris Schwartz stripped the plane down. My gut feeling is to go with Paul on this.
bugbear":8f4usfs4 said:Student":8f4usfs4 said:...is that I noticed that Paul Sellers makes the point that you should keep the blade and cap iron in place when flattening the sole whereas Chris Schwartz stripped the plane down. My gut feeling is to go with Paul on this.
The helpful people on OLDTOOLS checked and measured on this question. (They did it,
so you don't have to ... )
You do need to have the frog installed and tightened; but the blade, cap iron and lever cap have no significant effect.
This is not true of a wooden plane where the blade and wedge substantially deflect the body.
As AndyT mentioned, I've put quite a lot of effort into this topic;
I believe the approach that I've developed with help from others, and adopted for my own use, is practical, accurate and effective.
my original page, evolved over time
page on the principles
page on the practise, including a montage of progress shots
BugBear
There may be some of that, but however much there is it doesn't appear that this is an issue in practice.Student":3emcq9rt said:I measured the thickness on both a belt from my belt sander and a piece cut from a roll. Both were over 1 mm thick and I wondered whether, in pressing down on them, even on a hard flat surface, would compress the paper by a few thou thus rendering the flatness of the plate immaterial.
All of them work. This is a little like in sharpening discussions where people tend to get caught up in debating the pros and cons of their favourite system, going back and forth trying to successfully argue what's best. But a message that tends to get lost in the shuffle is that they all work.Student":3emcq9rt said:As such, I thought that wet and dry would be a better bet if “stuck” down with water. This is what Jacob and others seem to recommend although there seems to be a debate as to whether to use water or white spirit. Of course others maintain that ordinary abrasives stuck down with adhesive are just as satisfactory as wet and dry.
That is a question I find particularly interesting, given how it is almost universally recommended to have the iron in place so the casting is 'stressed' or under working tension.Student":3emcq9rt said:One final thing, before I leave Jacob and D_W to continue their debate, is that I noticed that Paul Sellers makes the point that you should keep the blade and cap iron in place when flattening the sole whereas Chris Schwartz stripped the plane down. My gut feeling is to go with Paul on this.
An endless supply of Silverlines await you on Amazon should you want one at very modest costStudent":3emcq9rt said:P.S. If all else fails, I’ll just have to buy a new plane but that may be the subject of another post next year.
MusicMan":mcl6mob1 said:"The only way to be sure that you're using a flat reference surface is to acquire one of known, certified flatness."
Not the only way. The first ones were made by Whitworth using his famous test for a plane - take three and check them against each other. Similar to his test for a straight edge. The beauty of this is that you need no equipment other then a scraper and blue, and a dial gauge on a base and arm to show you how close you are.
However, for woodwork, as you say, we don't need to be this fussy. A small, secondhand, used engineers plate is likely to be fine for us. Especially if it is granite, since that chips rather than bends if damaged, so does not leave inaccurate bumps.
+1 for your post, though.
Keith
