It is with some trepidation that I venture on to a forum where the topic of capirons generates 240 posts in 10 days. However, here goes
Both Paul Sellers and Chris Schwartz have videos on You Tube about how to flatten the sole of your plane. Both use abrasive sheets stuck to granite plates. Chris Schwartz uses a cut up belt from a belt sander and Paul uses pieces cut from a roll. The question is "if you are using thick abrasive sheets, what advantage does a granite, or float glass, plate have over a thick piece of plywood or MDF"?
To avoid any notion of starting a sharpening debate, I am not looking for answers that say they shouldn't be doing it that way and the best way is ???. Whenever I see sharpening threads, I am always reminded of the quote about any set of experts. Ask 10 experts for the correct way to do something and you'll get 11 different answers.
